Just wanted to get some opinions on double sided wood burning fireplaces. Thinking of putting one on the greatroom’s exterior wall that is shared with the rear patio. I’m assuming there is some type of partition wall in the middle of the two that goes into one common chimney flue so you could use them at the same time. How wide are they, what type of rough opening is needed, any type of problems/potential problems, and/or anything you think I may need to know before going ahead with this project. Any webistes for manufacterers or photos. Thanks for your help and merry christmas!
I would consider that to be back to back verses double sided.
One chimney is doable but they need to have seperate dampers.
& you wouldn't want the patio damper open while burning in the great room, & vise a versa.
“How many observe Christ’s birthday! How few, his precepts! O! ‘tis easier to keep Holidays than Commandments.” —Benjamin Franklin
not only separate dampers, but separate flues too, or the drafting wil be a nightmare.
As you describe this, it is not a double sided fireplace. It is simply two fireplaces oriented back to back. Each would require its own flue up the chimney and it's own damper. Having 2, 3, or even 4 fireplaces share the same chimney is not at all uncommon.
designing for space and size -
A mason who builds these for me sizes the flue based on the size of the firebox openning. That way the draft is balanced. A flue will not draw well if it is too low, too large or too small. It can get even trickier for the interior one if the house is built tight or for the exterior one on a windy day. An air makeup supply might be a good idea for an interior fireplace in a tight new house.
If you are currently framing and need an openning/header size, you are already ahead of yourself, because you needed a footer for the masonry mass to support it.
If you intend to use prefab zero clearance instead of masonry and a false chimney chase, then you can google Majestic or Heatilator, select a unit, and download the spec PDF for sizing and clearances.
Wd. Brrning. Firplaces
Piffin. Question. Would you really need a damper for an outside fireplace?
Do you realize you're in a thread from 2006?
As an aside - if there is a way to keep the flue for the inside fireplace within the heated envelope of the house, it will draft much better.
I would recommend 2 flues inside 1 chimney.
Happy New Year...
That is a good point but more impoortant in the north than in the south
Point taken. I should add that if you intend to use your chimney for actual heat, which is less common everywhere, and probably more so in the South. I learned about Masonry heaters from a Canadian...
Treat every person you meet like you will know them the rest of your life - you just might!
Masonry chimneys on South facing exterior walls draft better too (due to solar heating). Edit to add: I believe Ben Franklin was a strong voice for chimneys on South walls. In this orientation, they will also be a solar heat sink in the winter (even when not in use) but will absorb less heat in the summer than a chimney on the East or West.
Edited 12/27/2006 10:14 am ET by basswood
Even though you'll "never use it", install gas pipe, or a raceway for the same, especially for the inside unit.
So it sounds like a back to back version should not have any problem with downdrafting. Any ballpark ideas on price?
;)I'll sit this one out...
back to back fireplaces
I have read these comments from a few years ago and was wondering how it turned out? I too would like to build a back to back fireplace for inside and outside, and am wondering how to go about it? We want it to be wood burning on both sides (have a gas one already in another room).
Test
Test?
Test what?
