I just ripped out a bar for a customer that had a sink in it. The bar was in the basement which I’m in the process of remodeling. I’ll be making a new bar which won’t be a pennisula set up, but it will be along a wall (like a kitchen cabinet). Dilema (aside from figuring out the new forum): The old drain is approx. 30″ from a wall. Old setup – 1 1/2″ copper drain line into drum trap then copper drain line into 4″ cast iron. Since I can’t use an S-Trap, any suggestions for running a drain through the floor.
I can send pictures if needed.
Thanks Dave
You could try using an undersink pump. I had the same situation where the drain was 30+ feet away. For $175 I bought the unit with pump that goes under the sink. It's basically a small sump pump in a short bucket. Mine was made by Zoeller, but Hydromatic, Drainosaur and others make them also.
Otherwise start sawing and hammering.
Good luck,
John
