Drainage plane under fake stone veneer
I’m in a part of the country where rot can be a problem. I want to install some stone veneer, but I am concerned about not having a sufficient drainage plane! Behind the stone/mortar/wire mesh etc., I was thinking of covering the house the way Building Science recommends for stucco–15# felt, a drainage/spacer mat (like Waterway), and 15# felt again. (The tests on synthetic housewraps make me want to stay way far away from it.)
Thing is, I’ve never used or seen a spacer mat. Does it have too much give for a stone veneer application? How do they hold up?
If I’m so worried about water getting trapped, should I just say “forget it” and do a 4″-thick natural stone veneer and have the plans for the footings extended accordingly? Does anyone have ballpark estimates for labor on a natural stone veneer of that sort? I’ve never done that, either.
Edited 1/20/2007 3:03 am ET by Reyesuela
Edited 1/20/2007 3:22 pm ET by Reyesuela
Greetings R,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
Rather than using a drainage mat, we use a rain screen of treated 1"x2" and another layer of ply. We flash the bottom and leave weep holes as with brick veneer.
http://www.jlconline.com/cgi-bin/jlconline.storefront/45b39956004427d227177f00000105b0/Product/View/0412manu
Ouch.Thanks everyone!
