Drawing and cutting arches
jross | Posted in Construction Techniques on May 15, 2009 07:08am
Chuck Miller has a post in his video blog, “There’s a Better Wayâ€, on drawing ellipses.
Since drawing arches is a often talked about subject here, I’ll pulled out an article from behind the pay wall that describes the process well.
You can find both the video and a link to the article in Chuck’s entry:  Drawing an Ellipse-ish
john ross — Web Producer
Edited 5/15/2009 10:32 pm ET by jross
  1. john7g | May 15, 2009 09:43pm | #1
    the 1st link is 404
    but the 2nd is way cool!  thanks!
    1. jross | May 16, 2009 05:33am | #5
      Link is fixedjross -- FH Editorial
  2. bennyd342 | May 16, 2009 12:25am | #2
    you sure that that is an ellipse?
    1. [email protected] | May 16, 2009 02:51am | #4
      It is an elliptical segment. But it is not half of an ellipse.Like someone else said, the two nails and a string were my preferred method. Now, that I have access to AutoCad and a roll plotter, I just draw them in AutoCad, and plot out a template.
      Edited 5/15/2009 8:01 pm ET by Jigs-n-fixtures
  3. KenHill3 | May 16, 2009 01:32am | #3
    As a draftsman I learned a couple ways to lay out ellipses. The TRAMMEL method, and the STRING method.
    My favorite for carpentry is the STRING method, which is great for larger ellipses, creates a continuous line, and all you need is a couple nails, stringline, and a pencil.
    Scroll down:http://www.uwgb.edu/DutchS/MATHALGO/Ellipses.HTM
  4. homedesign | May 16, 2009 10:30pm | #6
    Here is another method from 1911
    http://books.google.com/books?id=plY1AAAAMAAJ&pg=PA167&dq=William+a+radford+old+house+drawings#PPA186,M1
    1. AitchKay | May 17, 2009 02:47am | #8
      Way back when, someone wrote an article (in FWW?) using a jig like that, with a router attached.And I know that a similar jig was found in the Dominy family workshops when their stuff was cataloged for posterity.In the FWW article, IIRC, they used a dowel or something traveling in the groove, so a helper had to hold a block in the adjacent cross-groove to keep the dowel from straying off course.The tweaked way to do it would be with dovetailed grooves and dovetailed blocks with their ends eased/pointed to smoothly traverse the gaps.AitchKay
  5. MSA1 | May 16, 2009 10:56pm | #7
    I usually use my straight edge on its end and the same three nails. Seems to work just as well.
