Dremel Grout Removal Bits
Flips | Posted in Tools for Home Building on November 15, 2008 03:05am
Has anyone had any experience with the Dremel grout removal bits?  I have to regrout a tile countertop and was thinking of trying one of these bits to remove the existing grout.
  1. Proclive | Nov 15, 2008 06:23am | #1
    I thought that the whole contraption designed for the dremel was a waste of time. I have the xpr 400 and it was extremely hard to remove grout from in between tiles. I would try the dremel multi max with grout removing blade before I would use that thing again.
    1. KenHill3 | Nov 15, 2008 06:32am | #2
      For grout removal, an ocillating tool like the Dremel Multimax is the cat's pajamas. Using my Fein Multimaster, I removed grout from a whole kitchen and entry floor area and was disappointed when there was no more grout to remove. It was actually enjoyable to accomplish this job without the time and tedium.
      1. Flips | Nov 16, 2008 06:41pm | #3
        I decided to try the dremel bit in spite of the two responses I received.  I used the router base attachment with the 1/16" bit and was pleasant surprised by how well the bit performed.  I ran the dremel at full speed and lowered the bit in 1/8" increments. An added bonus was the dust created settled down on either side of the joint with very little dust being kicked up in the air.
        Admittedly I did not do a very large area (22 square feet of 12" x 12" tile with unsanded grout) but the job went rather easily and quickly and was an inexpensive compared to some of the other options for removing the grout
