I need to drill a 1/4 inch hole in a ceramic floor tile for a screw to secure the bifold door pivot. What is the best way to accomplish this while minimizing the risk to the tile?
Thanks for any help!
A standard carbide masonary bit will generally do the job. If the bit tends to wander when you're starting it (common on smooth glaze), use a sharp punch (eg, scratch awl) to very slightly dent the glaze, to give the bit a "home".
Properly bedded, ceramic tile is remarkably rugged. You're not apt to break it unless it's a lousy tile job to begin with.
happy?
Ceramic tile bit. Available at any home center, or hardware store.
It's only satisfying if you eat it.
Another vote for dustinf's tile bit. Much safer for the tile and a cleaner hole then a standard masonry bit...Buic
I usually use a sharp 1/8" masonry bit to get started and finish with a sharp bit of the needed diameter. The smaller bit, if sharp, walks very little, and the larger bit drills quickly with a pilot hole.
Just picked up a set of the spear shaped bits, but haven't had to try them yet.
A fellow finish carp who worked with a great deal of commerical hardware, often through tile, prefers to use a smallish regular highspeed steel drill bit to chip the surface then go the rest of the way with the masonry bit.
Good drilling,
Don
I'll third dustin's tile bit.
Gord
