drilling bamboo
bobl | Posted in Construction Techniques on May 9, 2006 05:50am
gunnu try here first, rather than knots.
what are the tricks to drilling large holes in bamboo?
trying to drill 3/8″ or bigger holes I split the bamboo, tried slowing down at the end, but still split.
I’m trying to build a deer knocker (chaser)
TIA
bobl          Volo, non valeo
Baloney detecter
    IMERC | May 09, 2006 05:58pm | #1
    I had luck with a sharp fostner bit and a clamped on inverted V notched block with a guide hole to keep the bit from skating...
    1/2" holes.... high speed and light pressure...
    done on a drill press...
    WOW!!! What a Ride!
    Edited 5/9/2006 11:02 am by IMERC
    IMERC | May 09, 2006 06:04pm | #2
    maybe a step bit would work...
    a piolet hole and finish hole in one application...
    WOW!!! What a Ride!
  3. Caseys | May 09, 2006 06:18pm | #3
    Use one of those hole saws that look like a circular drum with teeth along with a pilot bit (I just had a mind block on what they are called....geez). Anyway, they come in many different diameters and should have one that will work for you. If need a smaller hole then can heat up a pointed metal rod and burn the hole into the bamboo.
  • A Grand Rescue on the Coast
