drilling into concrete advice needed
btbhfh92 | Posted in General Discussion on August 5, 2014 01:31am
Anchoring strong-tie 4X4 post base into concrete tomorrow.  Need to drill depth of 2 1/4″  @  3//4″ diameter for lead shield.   I have a Bosch SDS and a cordless hammer drill available.   The pad of concrete was poured 24 years ago.
 I saved ten bucks by opting for a concrete bit to use with the cordless instead of the expensive SDS bit.   That set-up failed,  Should I have gone with SDS?  The 3/4′  concrete bit went nowhere with the 1/2″ cordless drill in dual mode after one minute of drilling.  I’ve seen good performance with this set up but have never drilled more than a 7/16′ bit.
any thoughst would be welcome and appreciated
regards
CarpNotes
  1. calvin | Aug 05, 2014 06:00am | #1
    Carp
    Rotary hammer drill and don't lean on it, let the drill do the work.
    I use Hilti but Bosch certainly will have the balls for the job.  Proper bits and tools aren't cheap, but neither is your time.
    MarkH | Aug 05, 2014 07:42am | #2
    Get an SDS bit, that will work for sure.  Or try drilling a smaller hole first with the hammer drill, before getting out the big bit.
  3. DanH | Aug 05, 2014 08:02am | #3
    A lot has to do with the makeup of the concrete.  Some has small aggregate or aggregate that fractures easily, and that can be drilled with a standard drill, within reason.  But if you have large aggregate that doesn't readily fracture you need a "real" hammer drill (or the good ol' star drill and hammer).
Versatile Vise
