Drip edge questions
Rebeccah | Posted in General Discussion on January 15, 2007 08:27am
At junkhound’s suggestion I’m breaking my list of roofing questions down a bit. This set is on drip edge. My fiance and some of his friends and I are going to reroof our garage, which is in generally crappy condition so we don’t want to spend a lot of money. It’s a simple gable roof, 2.5:12 slope, exposed rafters, with a curb on the front rake.
We want to apply standard 3-tab shingles (over a double-thickness #30 felt underlayment, as per GAF instructions for low slope roofs). The shingle instructions say to put the metal drip edge under the roofing felt at the eave, and over it along the rake.
– There’s a huge variety of metal roof edgings at Home Depot. Is there any guideline for which one to use? We were thinking about the 1.5″ wide L-shaped pieces that come in 10-foot lengths. I think it might be aluminum.
– Do we need a drip edge on the front rake if there’s a curb?
– Do nails penetrate through the drip edge OK?
– Do we need any kind of adhesive or sealant between drip edge and plywood, drip edge and roofing felt, or drip edge and shingles?
Thanks,
Rebeccah
    jarhead | Jan 15, 2007 09:27am | #1
    We nail drip edges through the felt into the plywood. Shingles go on top of this. No adhesive needed. I don't know what a "curb" is. If is what I think it is we call them rain diverters. That is for personal opinion. If it were my garage and they were installed on the roof above the garage doors, I would use them. Keeps water from screaming down on you as you go into the garage.
    Semper Fi
    "To be young and a conservative, you have no heart"
    "To be old and a liberal, you have no mind"
    Winston Churchill
    "Some people spend an entire lifetime wondering if they made a difference. The Marines don't have that problem."
    PRESIDENT RONALD REAGAN, 1985
    Edited 1/15/2007 1:36 am ET by Jarhead
    1. Rebeccah | Jan 15, 2007 09:22pm | #4
      Here's a photo of the garage.http://forums.taunton.com/tp-breaktime/messages?msg=84033.10Rebeccah
      1. semple | Jan 17, 2007 03:42am | #6
        tear it down
        1. stevent1 | Jan 17, 2007 04:16am | #7
          Likewise. Tear it down.
          Chuck S
          1. semple | Jan 17, 2007 04:53am | #9
            why would you want to waste your time .big waste of time and money
          2. Rebeccah | Jan 17, 2007 05:22am | #13
            ---Time: We have some, we enjoy building things (my fiance is an artist and I'm a retired orthopaedist AKA bone carpenter), and this is something we haven't done. In short, it's fun. The weather is supposed to be good all week and I have vacation this week.Money: This is the least expensive option that leaves us with a structure that is standing and sheds water.We're doing some structural work at the same time, more than the minimum I was willing to commit to because we do have the time and the weather is cooperating.Waste: I am aware that this is not Fine Homebuilding. I have to be selective what work I hire out to people who know what they are doing and have a good reputation, making space in the budget for a quality job -- and what jobs we hack through ourselves with some help from our friends. This is one of the latter.Rebeccah
          3. Piffin | Jan 18, 2007 01:36am | #21
            Not picking on you, just curious - and it really is none of my business, but - How do you get to have a weeks vacation when you are already retired?I get it - workeing on this is a vacation from being retired, you are back to work again.;)
          4. Rebeccah | Jan 18, 2007 06:37am | #25
            I left orthopaedic surgery after 5 years in solo private practice in central Illinois. Why is complicated, but the bottom line is I don't fit in with other physicians all that well, and I stressed out and didn't delegate well as a business owner. It just wasn't a good fit. I moved to the SF Bay area to a software company and have been doing Java programming for the last 6 years. So I've gone from being self-employed with a C corporation to being someone else's employee. I also went from small clique-y town to a more consmopolitan environment filled with activities and people I enjoy, and loosened up enough to meet and fall in love with a member of the opposite sex. He's everything I'm not, and appreciates what I am.Rebeccah
          5. MikeSmith | Jan 18, 2007 02:23pm | #26
            soooooo.... rebeccah.. have you & kalim thought about Mt. Tremblant for your honeymoon ?
            supposed to be quite the place in August
            anyways... non illigitimi carborundum... carpe diem ,  etc....
            and there's always..." roofing as therapy"Mike Smith Rhode Island : Design / Build / Repair / Restore
          6. Rebeccah | Jan 17, 2007 05:11am | #11
            --- Likewise. Tear it down. ---That issue's already been addressed. We need it and we can't afford to replace it. It stays.Rebeccah
      2. pickings | Jan 17, 2007 04:45am | #8
        You got enough decking on the edge to attach the drip edge to?
        1. Rebeccah | Jan 17, 2007 05:14am | #12
          --- You got enough decking on the edge to attach the drip edge to? ---We will. We've stripped off the roofing and the rotten sheathing from around the edges. We're in the middle of patching the sheathing with plywood and then we're going to overlay with another layer of plywood to smooth it out.Rebeccah
  2. Stilletto | Jan 15, 2007 01:56pm | #2
    Put the drip edge on before you put the tar paper on.  I put it on with the same stapler I use for the paper.  It will get nails through it when you shingle it.
    On your eaves be sure to put a starter shingle (shingle cut in half lengths) on first then start your courses of shingles.
    1. Rebeccah | Jan 15, 2007 09:23pm | #5
      Good idea about stapling. I knew about the starter course. Thanks.Rebeccah
  3. Piffin | Jan 15, 2007 02:01pm | #3
    If this is that garage that is readay to fall down, get the cheapest you can find or do without.
    Metal drip edge should always go under the shingles.
    On that curb - I saw that in earlier photo and wondered why in the world it is there. I think it would be easier to remove it than to deal with special flashing situations for it.
    Edited 1/15/2007 6:03 am ET by Piffin
    gdcarpenter | Jan 17, 2007 04:54am | #10
    It's a nit, but on the eave the drip molding should go under the tar paper, on the gable ends the edge molding should go on top of the tar paper.
    Let's not confuse the issue with facts!
    1. Rebeccah | Jan 17, 2007 05:23am | #14
      --- It's a nit, but on the eave the drip molding should go under the tar paper, on the gable ends the edge molding should go on top of the tar paper. ---Thanks. I did see that on the shingle instructions, so it's good to have it confirmed.Rebeccah
      1. roofguy | Jan 17, 2007 06:44pm | #18
        OK, firing another shot in the drip edge war... I always install the felt first and then the drip second, even on the eaves. On the rakes, if you put the drip first, wind-blown rain could be forced under the felt to the wood decking. The drip edge on top holds the felt tight to the deck and any rain under pressure will be driven to the top side of the felt. I also would run a thin, continuos bead of sealant down the drip edge as I shingled the edge up, if the rake edge faced the prevailing winds. DO NOT use cheap "tar-in-a-tube"!! It will bleed oils in the heat! I generally use a sealant just for this purpose made by OSI called RF-140, but I think any good quality, butyl or urethane caulk would do.( NO SILICONE! )
        As far as the eaves, drip over the felt for the same reasons, plus the surface of the drip edge in a better surface to seal to than the felt. I know this seems to be wrong because the drip is bucking water, but shingles are a water-shedding system, and you will have two layers of shingles shedding water over the drip edge.. Cut the starter shingles so the sealant strip is is at the bottom edge of the drip edge as the shingle wrapper says. Just prior to nailing on the starters, apply dabs of sealant spaced about 3"-4" apart on the surface of the drip edge to seal down the starter course. If the rest of your roof is sealed down, it makes sense to seal the starters down too.  I know a lot of the other roofers out there will say that my methods are too time consuming, but I feel that a little extra time spent during the installation avoids  a lot of potential problems down the road!
        getting a little too chatty...
        1. Rebeccah | Jan 17, 2007 08:07pm | #19
          Just curious, roofguy, what is the rationale for the traditional putting the dripedge under the tarpaper at the eaves? I understand your rationale for putting it over.Rebeccah
          1. roofguy | Jan 17, 2007 08:33pm | #20
            Generally roofing is done from the bottom up to shed water, which generally runs from the top down.
        2. Piffin | Jan 18, 2007 01:39am | #22
          Me too, but on something like this one, I ain't going to make a point of arguing it.
  5. MikeSmith | Jan 17, 2007 06:11am | #15
    rebecca... you have 5 threads by my count... all about the same subject... your house & garage
    everytime you start a new thread , you lose half your audience... ( or , at least, you lose me )
    if you had kept things in one thread , then it's easy to reference back and pull things forward
    and links are good .. but they are also distracting
    i would think you should stick to thread number 3..... ( the one where you started yelling at the help )...
    but hey, whadda i no ?
    1. stevent1 | Jan 17, 2007 06:41am | #16
      Mike,
      You know more than most folks forgot.
      Chuck S.
      Edited 1/16/2007 10:42 pm ET by stevent1
    2. Rebeccah | Jan 17, 2007 09:08am | #17
      OK, you're clearly not in junkhound's corner on this issue. :)But I agree, I'll keep further garage posts to the "DIY after all" thread.The house is a separate issue, despite being also a roofing question. Rebeccah-- Da dah, dah. I've learned my lesson well. You know you... can't please everyone, so you've... got to please yourself....
    3. Piffin | Jan 18, 2007 01:41am | #23
      She started on with all her Qs in one place and Junkhound told her to spread it out to gain audience. think we oughta take him out back in the alley?
      1. MikeSmith | Jan 18, 2007 02:57am | #24
        no.. alleys are too tempting for junkhound.. he'll find something and start salvage
        what you wanna do with him is  lure him into a tea  potty.. kill him with boredomMike Smith Rhode Island : Design / Build / Repair / Restore
