Drive way, how thick?
| Posted in General Discussion on May 17, 2004 06:01am
I am planning on putting in a carport and I will be installing (putting in, pouring, ect.) a driveway, or maybe I should call it a drive strip, you know, 2 strips-one for each tire.  I was thinking something 16-18″ wide, but I didn’t know how thick to make it.  If I make it 4″ thick will I be repouring it in a year.  Or will 4″ x 16″ x 10′ (with some mesh) last.  just normal cars, minivans, will be using it.  Thanks.
  1. danlott | May 17, 2004 07:52am | #1
    I am no concrete expert, but I would dig down and put atleast 6 inches of base material and compact.  I would then pour it 6 inches thick with wire mesh.
    Dan
    "Life is what happens when you are making other plans." - John Lennon
    BossHog | May 17, 2004 03:55pm | #2
    Every residential drive I've seen around (central Illinois)here is 4" thick.
    The politicians don't just want your money. They want your soul. They want you to be worn down by taxes until you are dependent and helpless. When you subsidize poverty and failure, you get more of both. [James Dale Davidson]
    SamT | May 17, 2004 04:47pm | #3
    http://forums.taunton.com/tp-breaktime/messages?msg=43357.1
    Arguing with a Breaktimer is like mud-wrestling a pig -- Sooner or later you find out the pig loves it. Andy Engel
  4. sungod | May 17, 2004 10:36pm | #4
    My driveway will hold a concrete truck, it has 4" of concrete.  The secret is concrete trucks were driven over it before it was poured.  Drive your cars on the dirt before you place concrete.  Any soft spot that wont support the concrete will end up as a depression that you will compact dirt in those low spots.
    1. 1coolcall | May 18, 2004 12:08am | #5
      car as steamroller good idea,
      thanks Sungod and others.
  5. WayneL5 | May 18, 2004 12:16am | #6
    The base must be well compacted.  Driving on it is probably not enough.  I'd make sure you use crushed stone (the sharp stuff) not rounded gravel, and use a jumping jack tamper.  Plate tampers are for cosmetic, not structural, work.
    Rebar should be 2" from the bottom of the slab.
    1. 1coolcall | May 18, 2004 01:40am | #7
      If I am doing a 16" wide strip, should I have lots of expansion joints (say, every 3 feet), or should I go longer (say, every 10 feet)?  Compaction, compaction, compaction.
      1. WayneL5 | May 18, 2004 01:47am | #8
        I can't give an authoritive answer.  Old "driveways" had frequent joints when they used strips.  I'm picturing my grandfather's house.
        1. donpapenburg | May 18, 2004 02:42am | #9
          But they were mixed by hand.
        SamT | May 18, 2004 03:07am | #10
        You can use strips up to 16' long if you go 5 1/2" thick and use 2 @ #3 rebar.
        SamT
      3. Dagwood | May 18, 2004 09:30pm | #13
        Sidewalks around here (Southern Ontario) - loads of frost and salt. Are poured  4" thick between drives, 6 inches at driveways. There is to be a compacted 4 inch gravel base under them. Expansion joints are every 25 feet with a sawcut or pressure relief joint every 5 feet. (Expansion joints are to be lined with fibrous material, pressure joints are just controlled cracks). On the job we aren't too picky about measuring off distances between joints. Most concrete guys use a rake handle to measure off the 5 ft joints, and put in expansion joints every 5th joint and at either side of every driveway.
        I would imagine that these specs are more than adequate for a residential driveway, however, if it were my own house, I would pour before it got too hot out, and not drive on the new driveway for about 3 days.
        The most important thing for your drive is not so much the concrete, but what you have under it. A good base makes a good driveway.
        DagwoodView Image
  6. MisterT | May 18, 2004 07:24pm | #11
    It should reach from the bottom of the tires to the top of the substrate.
    I can post a diagram if you need one.
    Mr T
    Happiness is a cold wet nose
    Life is is never to busy to stop and pet the Doggies!!
      BossHog | May 18, 2004 09:17pm | #12
      "Happiness is a cold wet nose"
      Ever hear of a commedian by the name of Jerry Clower? He told a story once that your tag line made me think of.
      It seems a country boy showed up rather late for school one morning. The teacher met him at the door and asked him why he was late.
      He said early that morning his Pa thought he heard a noise in the chicken house. So he jumped up, grabbed his shotgun, and headed outside wearing nothing but his nightshirt. He snuck aound the corner of the chicken house, thinking there was a fox in there.
      As he slowly pushed the chickenhouse door open, one of the coonhounds walked up behind him and stuck his cold nose up under Pa's night shirt.
      And well, Ma'am, we've been cleanin' chickens ever since.
Old House Air-Sealing Basics
