Driveway apron width per car
PeteDraganic | Posted in General Discussion on July 1, 2009 06:06am
I am designing a new driveway for my home to accommodate the growing number of drivers here. Drive is 100′ long and I plan to keep it single-laned but then add an apron off to the side for all cars to park on. How much width per car should I figure for a comfortable but reasonable fit? For example, if I make it 18 deep by 50 wide, is that a good size for 5 cars?
I refuse to accept that there are limitations to what we can accomplish.        Pete Draganic
Take life as a test and shoot for a better score each day.          Matt Garcia
    CapnMac | Jul 01, 2009 09:07am | #1
    Most code-defined parking spaces are 9' wide by 18-19' long.
    8' width can be used, but it can be narrow if anyone drives wider rides, dualies, the like.
    That help any?
  2. Hudson Valley Carpenter | Jul 01, 2009 09:54am | #2
    That's perfect...if their drivers have enough room to straighten out the vehicle as they enter the space.  That would add at least twenty-five feet but you should do some experiments in empty parking lots with drivers of average skill, and a tape measure.
    1. VinceCarbone | Jul 01, 2009 02:14pm | #3
      Pete,
       I'll be happy to come visit and park in your driveway to show you how much room you'll need.   Vince Carbone
      Riverside Builders
      Franklin,NY
    Jeff_Clarke | Jul 01, 2009 02:58pm | #4
    Wide enough, but not quite deep enough, depending on the vehicle.
    9 x 19 = compact car parking
    10 x 20 = standard car parking
    I'd go for closer to 20 feet deep considering that, for instance, a Chevy Suburban LT1 or similar is already 18 feet long, vs. standard vehicles which run 15'-16' long.
    1. FastEddie | Jul 01, 2009 03:59pm | #5
      18 feet works if the bumper overhangs the grass.  10 ft wide would be minimum.  Ditto earlier comment about room to turn into the space."Put your creed in your deed."   Emerson
    boiler7904 | Jul 01, 2009 09:55pm | #6
    50' is wide enough for 5 cars.  I'd go at least 20' deep for the parking area but you might consider going deeper if you have the room unless you're planning diagonal parking instead of perpendicular (to the main drive).  The reason I'm saying that is the typical parking lot aisle is 24' from parking stall to parking stall.  If you only have the width of a single lane driveway to back into, you'll be doing a lot of 3 and 4 point turns to get headed out the driveway.
  5. oldbeachbum | Jul 01, 2009 10:44pm | #7
    doors dingers, or do you care?.....depends on who's parking.....10ft should be good.....we did one at 12' for a motor home
    I'm not flippin' you off.........just counting cubits
  6. MikeSmith | Jul 02, 2009 03:40am | #8
    10 x 20 with a 24" turning / backing radius
    unless vince shows uo...then double everything
    1. brownbagg | Jul 02, 2009 04:39am | #9
      two cars 16 feet wide,and its real tight
