dry wall fastening
user-54917 | Posted in Construction Techniques on November 20, 2005 03:11am
Searching for a product in recent issue. Clips to put on butt end of g.w.b. so that there is no need to break on a stud.
  1. calvin | Nov 20, 2005 03:31am | #1
    This isn't like corner clips for fastening board to adjacent framing, but it would do what you want and supposedly, make taping easier.    http://www.ezbacker.com/butthanger.html
    Quittin' Time
  2. DonCanDo | Nov 20, 2005 06:14am | #2
    I made my own butthangers for a ceiling job recently.  I just used some 5/8" X 12" strips of plywood with 1/8" shims running down each edge.  It worked out really well for hiding the butt joint, but it did take me a bit more time to spackle.
    By the way, what's a g.w.b.? (and don't tell me George W. Bush).
    -Don
    1. HeavyDuty | Nov 20, 2005 06:21am | #3
      That's funny Don.
      Why do you want to put clips on the butt of g.w.b.?
      1. user-54917 | Nov 20, 2005 07:03pm | #9
        Tom This connection would eliminate the need for one cut and reduce waste. Also it provides somewhat of a recess for finishing.
    2. calvin | Nov 20, 2005 06:22am | #4
      gypsum wall board
      Quittin' Time
      1. HeavyDuty | Nov 20, 2005 06:32am | #5
        He knows.
        1. calvin | Nov 20, 2005 06:36am | #6
          no ####?A great place for Information, Comraderie, and a sucker punch.
          Quittin' Time
          1. HeavyDuty | Nov 20, 2005 07:23am | #7
            :0)
    3. user-54917 | Nov 20, 2005 06:59pm | #8
      Don G.W.B stands for gypsum wall board. thanks for response however not the solution Iwas looking for.
  3. 5brown1 | Nov 22, 2005 07:26am | #10
    I picked up some called butt backers from a drywall supply house. They were pretty cheap - about $2 each. They worked great on the 1/2" but not quite as well on the ceiling 5/8".
    PeteDraganic | Nov 24, 2005 04:56pm | #11
    I am not familiar with the clips either but would sugggest ripping some 1/2" plywood into strips and screw through the drywall into the ply to  create a backer at each free joint.
    This should provide a fairly cheap and easy way to remedy your prob.
    The difference between stupidity and genius is that genius has its limits. -Albert Einstein
    http://www.peteforgovernor.com
    1. dinothecarpenter | Nov 24, 2005 05:23pm | #12
      Thanks for the above.
      ... make my day.
      YCF D
