Hi all I am new to the board and this is my first post. I am doing my laundry room over which is in the basement and I was wondering if you can use pvc or any other product for the dryer vent. I know most just use the tin or just buy the flex hose but I just don’t like the way it looks. The vent is going to be exposed and has to go about 5 feet up from the floor, make a 90 degree turn, go about 4 feet and make another 90 degree turn, then 5 feet until it’s outside. Thanks for the help.
Steel duct is best IMO. Less concern about fire.
If it's a gas drier, you have to use steel ducting. Avoid flex duct as it creates too much turbulence and backpressure.
Why are you using two elbows and making such a long run? Keep it short with as few turns as possible to get good flow and prevent lint clogging the system (which can also be a fire hazard).
Solar & Super-Insulated Healthy Homes
Here in NY it's against code to use PVC. My plumber tells me it will melt from the inside and seal up. I believe your stuck with galvanized or aluminum pipe. The newer dryers can get extremely hot also and the ones with steam features create ALOT of moisture so be sure to pitch the pipe properly. PS. U do have alot of 90's
Edited 3/15/2008 8:10 pm ET by Pelipeth
Whatever you do, don't use the plastic flex vent hose. Four inch round metal will work fine as long as you:
Sorry I did leave out a few things. I live in NY, it's an electric dryer, and the reason for so many 90"s is it is by an outside wall. On the otherside of that wall is a crawl space for my kitchen so I have to make a few turns to vent it out so it is not under the house. Thanks for the help.
Then move the drier.
Riversong HouseWright
Design * * Build * * Renovate * * ConsultSolar & Super-Insulated Healthy Homes
No to PVC. Its a fire hazard. Having said this my old house had PVC fr over ten years.
I recently turned it into a rental so I removed the PVC and installed the required rigid metal (use metal tape on joints not screws).
The PVC I removed was completely covered in lint. The whole run about ten feet.
Don't use flex for dryers. Ever. It collects lint inside like you wouldn't believe.
The aluminum, snap-together vent pipe is what's used for 90% of installations, and it gives perfectly good service. Just be sure that all sections of the pipe are accessible somehow for cleaning.
