Drylok – does this work at all?
CeltsFan | Posted in General Discussion on June 29, 2008 05:12am
We’ve been having some seepage in one corner of our house.  It’s curious, because I took a look at the gutters, landscaping, etc. – and it seems like the situation should be okay. Regardless, I’m going to pull the gutter runoff even further away from the house and work on making sure the grade very much slopes away from the house.
So, while I’m going to do everything I can on the outside, I was thinking that using a can of Drylok on that corner could help a bit as well. Anyone have any experience with this? Does it actually work?
  1. alwaysoverbudget | Jun 29, 2008 05:54am | #1
    do you have a crack or does the wall get moist and run water? if it seeps through the wall i have used drylock with pretty good success.there might be something better  that a basement contractor uses ,but i don't know what.
    if a man speaks in the forest,and there's not a woman to hear him,is he still wrong?
    1. CeltsFan | Jun 29, 2008 03:10pm | #2
      I generally think it's just moisture seeping through.
  2. MSA1 | Jun 29, 2008 04:07pm | #3
    My problem the products like Drylock is that you're stopping the water on the wrong side. If the product does what it says then you end up with a completely wet foundation and now the water that has been permeating the wall now has no where to go.
    Seems its always better to fix from outside. I know no one wants to hear that but its usually true.
    McDesign | Jun 29, 2008 04:14pm | #4
    I've had good luck with it in my shop.  It's ~4' below grade on three sides; five rows of block, filled with vermiculite (got a bunch free), tarred on the outside with the normal stuff.
    Had some seepage in heavy rain when first built (it's at the bottom iof a slope); used the powdered Drylock you mix with water; no dark damp spots since, eight years later.
    I did drill a hole for a TapCon to mount a vacuum floor sweep; water actually came up through the hole around the screw in a heavy rain!
    Wonderful to "paint" with, too - like spreading whipped cream on toast!
    Forrest - dry
Mortar for Old Masonry
