Drywall Access Panels
Nuke | Posted in Construction Techniques on February 24, 2010 08:06am
Morning All,
I am trying to come up with some similar to low-voltage drywall frames that provide the ability to mount faceplates. I have to cut in some access holes for the PRV (about 10″ above household water cutoff), and also a couple of access holes for basement water and natural gas.
While making holes is easy, I need a solution that gives a finish look. Anyone know of anything? This would be akin to a tiny eletrical panel door.
  1. MGMaxwell | Feb 24, 2010 08:22am | #1
    Google "Drywall Access Door"
    Google "Drywall Access Door" and you'll get a bazillion hits. Vendors offer many sizes and varieties.
    xxPaulCPxx | Feb 24, 2010 12:11pm | #2
    I get stuff from these guys:
    http://www.warehousebay.com/
  3. gfretwell | Feb 24, 2010 12:42pm | #3
    How big are the holes? will a 4x4 "low voltage" ring with a blank cover work? That is what we use for Ufer ground connections that have to remain accessable.
  4. MGMaxwell | Feb 25, 2010 08:14am | #4
    http://www.accesspanelsolutions.com
  5. JeffinPA | Feb 26, 2010 08:11pm | #5
    have you tried the big box stores?  I get snap in plastic/vinyl covers at  HD that work great for the intended purpose.  From 6x6 to about 12x12 if memory serves me.
    anything bigger than that, i put in a door of some sort.
Big Doors Have Big Challenges
Engineered materials and vacuum-press laminations prevent warping and keep a tall, flush-panel door from being excessively heavy.
