Drywall Alternatives
yukon_john | Posted in General Discussion on May 20, 2009 05:25am
My authority having jurisdiction, also know as Katy, doesn’t want drywall in our new house that is under construction.  I found a couple of products that are similar to drywall but are made from magnesium oxides.  Anyone use these products?
http://magnesiacore.com/index.html
http://www.dragonboard.com/
  1. ted | May 20, 2009 05:30pm | #1
    For what reasons? Environmental concerns?
    BarryE | May 20, 2009 06:28pm | #2
    Plaster?
    she doesn't want drywall finish or wallboard products
    Barry E-Remodeler
    xxPaulCPxx | May 20, 2009 09:02pm | #3
    Wow, looks like one of those great products that cost three times as much and only available on one side of the country... the one you are not on!
    I'm a little suspicios when Dragon Board says "No energy is consumed in manufacturing DRAGONBOARD."  That is a copy-paste from their web site.
    Neither place has a dealer locator.
    Tu stultus es
    Also a CRX fanatic!
    Look, just send me to my drawer.  This whole talking-to-you thing is like double punishment.
    1. brucet9 | May 21, 2009 03:45am | #4
      "No energy is consumed in manufacturing DRAGONBOARD."Maybe they mean no NET consumption of energy. Perhaps the machinery is run by electricity generated from radioactivity coming off the DragonBoard material. :)BruceT
  4. WayneL5 | May 21, 2009 04:32am | #5
    If you could describe what the supposed problem with gypsum drywall is we'd be in a better position to comment on alternatives.
  5. ruffmike | May 21, 2009 05:15am | #6
    I've seen wheatboard installed on walls before, in a batten board style. It was stained and had a unique look.
    http://www.naturalbuilthome.com/products/349-wheat_board
                                Mike
        Small wheel turn by the fire and rod, big wheel turn by the grace of god.
    1. mackzully | May 21, 2009 05:29pm | #10
      Yikes, that must have been an expensive house, around here 4x8' Wheatboard is between $150-200/sheet! I've found that Advantech/HomeAdvantage looks very similar to a lot of the 'green' sheet products when polyurethaned. Plus it's about 10x cheaper, and probably even greener than the green boards. I'm convinced that eventually all the greenies will fall in love with OSB, especially when it's the cheapest, greenest, non-formaldehyde sheet product available in every big box.Z
      1. ruffmike | May 23, 2009 02:49am | #12
         It was actually a Kaiser medical building, and the board they were using was a Kaiser building product.
         I had no idea it could cost so much. There is a Japanese product that is similar also that I saved a link to, http://www.kireiusa.com/pdfs/KirWht_SpecSheet_Aug08_F.pdf
         Someone posted pictures here of a finished osb floor, it looked pretty cool.                            Mike
  6. Pelipeth | May 21, 2009 11:56am | #7
    Might be easier (and better off) finding a replacement for Katy.
    1. dude | May 21, 2009 12:45pm | #9
      Panneling & accoustic tiles on ceiling for retro look
      Barn board on walls for country look
      Tin ceilings & plywood on walls stained & varnished for nut job look
      Seen all the above one place or another
  7. Hackinatit | May 21, 2009 12:44pm | #8
    I'd want the fire protection of drywall. I'd cover the drywall with whatever the final finish.
    A La Carte Government funding... the real democracy.
  8. Hudson Valley Carpenter | May 21, 2009 07:03pm | #11
    I've considered using rock lathe and plaster in certain areas of my own home.  But if my DW demanded something like that, I'd tell her that I'd install the rock lathe and that she should be ready to grab a hawk and a trowel, load up and get started.  And she should hire a hod carrier too.
    The reason that drywall is so popular is the price of gypsum, near nothing, and its ease of application.
    As someone else said, if you tell us what it is about drywall that Katy objects to, we can probably come up with some good alternatives, as well as the difference in cost/sqft.  That last part will probably make "good old drywall" seem like a long lost brother, when you total up the extra expenses.
  9. cut50 | May 24, 2009 05:49pm | #13
    In your location I`d use moose hinds.lol
Outdoor Lighting
