drywall corner cracks
| Posted in General Discussion on October 17, 2003 06:44am
 My house for the most part sits on clay soil, there is some house movement with expansion and contaction.  I have vertical corner cracks from floor to ceiling of both side of a wall that’s perpendicular to exterior wall. Mud had been applied but the cracks reappeared. has anybody used paintable sealant for corner cracks? I believe the sealant would be flexible enough to accomodate movements, but when spraying texture, will it stick to sealant? what kind of sealant would you recommend? Or applying fiberglass mesh a better route? any suggestions?
thanks
  1. WayneL5 | Oct 17, 2003 09:08pm | #1
    I've used siliconized acrylic latex caulk successfully.  It leaves the corner slightly radiused, but no one notices.  It probably won't hold for decades, but I put some in a problem corner about 10 years ago and it's still fine.
  2. csnow | Oct 18, 2003 12:18am | #2
    2nd for trying simple latex caulk here.  Mud is too brittle.
    Coatings will stick to it fine.
      MarkH | Oct 18, 2003 03:00am | #3
      There is flexible mud.  I've never tried it, but I have seen it.  Caulk is probably best, but it will eventually shrink and crack.
