Can someone please explain a finish level 4 on sheetrock for me! I would appreciate it.
Understand lumens, ceiling brightness, beam spread, tilt, and color options to make a wise choice on a common fixture that can range from $75 to $750 or more.
Levels Of Gypsum Board Finish
LEVEL 0: No taping, finishing or accessories required. This level of finish may be useful in temporary construction or whenever the final decoration has not been determined.
LEVEL 1: All joints and interior angles shall have tape embedded in joint compound. Surface shall be free of excess joint compound. Tool marks and ridges are acceptable. This level of finish often referred to as "fire taping", is frequently specified in plenum areas above ceilings, in attics, in areas where the assembly would generally be concealed, or in building service corridors and other areas not normally open to public view. Accessories (cornerbead, base shoe other trims) optional at specifier discretion in corridors and other areas with pedestrian traffic.
LEVEL 2: All joints and interior angles shall have tape embedded in joint compound and one separate coat of joint compound applied over all joints, angles, fastener heads and accessories. Surface shall be free of excess joint compound, tool marks and ridges are acceptable. This level of finish is specified where water resistant drywall is used as a substrate for tile; may be specified in garages, warehouse storage or other similar areas where surface appearance is not of primary concern.
LEVEL 3: All joints and interior angles shall be tape embedded in joint compound and two coats of joint compound applied over all joints, angles, fastener heads and accessories. All joint compound shall be smooth and free of tool marks and ridges. Note: It is recommended that the prepared surface be coated with a primer/sealer prior to the application of final finishes. This level of finish is typically specified in appearance areas which are to receive heavy or medium texture (spray or hand applied) finishes before final painting, or where heavy-grade wall coverings are to be applied as the final decoration.
LEVEL 4: All joints and interior angles shall be tape embedded in joint compound and three coats of joint compound applied over all joints, angles, fastener heads and accessories. All joint compound shall be smooth and free of tool marks and ridges. Note: It is recommended that the prepared surface be coated with a primer/sealer prior to the application of final finishes. This level of finish is typically specified where light textures or wall coverings are to be applied, or economy is of concern.
LEVEL 5: All joints and interior angles shall be tape embedded in joint compound and three separate coats of joint compound applied over all joints, angles, fastener heads and accessories. A thin skim coat of joint compound, or a material manufactured especially for this purpose, shall be applied to the surface. The surface shall be smooth and free of tool marks and ridges. Note: It is recommended that the prepared surface be coated with a primer/sealer prior to the application of final finishes. This level of finish is recommended where gloss, semi gloss, enamel or nontextured flat paints are specified or where severe side lighting conditions occur. This highest quality finish is the most effective method to provide a uniform surface and minimize the possibility of joint photographing and of fasteners showing through the final decoration. (note: Application of primer/paint products over Level 4 and Level 5 smooth finish: Industry experience demonstrates an effective method for achieving a visually uniform surface for both the primer and topcoat is spray application immediately followed by back rolling or roller application using good roller techniques such as finishing in one direction and using roller types and naps recommended by the paint manufacturer.
Solar & Super-Insulated Healthy Homes
Thanks very much to Riversong and Hammer1 for the accurate info!Been doing this for almost thirty years and we just either fire-tape or finish like walls are getting semigloss paint everywhere. P.S. where did Riversong get that info?
Google Levels of Dry Wall finish.
I got it from:
http://www.drywallconstruction.com/levels_of_finish.htm
But it can be found at any drywall manufactur's website.
Riversong HouseWright
Design * * Build * * Renovate * * ConsultSolar & Super-Insulated Healthy Homes
Level 4 is what most of us would consider a normal interior taping job. Three coats of mud on screws, flat joints and outside corners. A minimum of two on inside corners, all sanded smooth and ready for paints. Lower levels get used for places that don't have to be smooth and painted, such as an adjoining garage wall and places that aren't seen, like marriage walls in attics. Level 5 means the entire surface of the sheetrock is coated with a thinned compound in addition to the level 4 taping. If you are using a high gloss paint or may have a large expanse of wall, this will hide the level 4 taping from telegraphing through the paint and showing the difference in texture between sanded compound and paper.
