Drywall Hammer: Who Uses the Hatchet?
| Posted in General Discussion on November 2, 1999 04:19am
What the heck is that hatchet for? Does anyone use it?
  1. Guest_ | Oct 26, 1999 08:50pm | #1
    Jody,
    The hatchet has a number of uses such as marking ceiling joists on the top plates quickly. Mainly though,I think it gives you a flat surface attached to a lever that when slipped between or under sheets, where you cant get your fingers, helps you manipulate them.
    JonC
    1. Guest_ | Oct 27, 1999 02:10am | #2
      *Jody,
      You must remember that the "drywall" hammer is a variation of the "lathers" hatchet. It was use to quickly mark a cut lath.
      Joseph FuscoView Image"The price of apathy towards public affairs is to be ruled by evil men." -- Plato
  2. FELIX_VALDEZ | Nov 02, 1999 04:14am | #3
    golden rule number 5 when in doubt chop it out. one more use of the drywall hammer. when installing drywall for money .choping small pieces off in the air is faster installation .rule number 4 when your thinking long your thinking wrong.Hence the reason for the hatchet. trimming with hatchet is better that lifting sheet over again.
  3. Jody_Sienger | Nov 02, 1999 04:19am | #4
