Drywall hint
DanH | Posted in Construction Techniques on January 11, 2008 07:53am
Gotta credit my wife for this:
When prepping torn drywall for skimcoating (eg, where tile has been removed) use a coarse dish “scrubby” (or coarse steel wool) to lightly scour the surface. This removes a lot of the loose paper “tags” without ripping off additional paper.
If your view never changes you’re following the wrong leader
    IMERC | Jan 11, 2008 08:02pm | #1
    I'll remember that one...
    WOW!!! What a Ride!
  2. dovetail97128 | Jan 11, 2008 09:11pm | #2
    After that if you spray Kilz on the raw paper it seals it off from the moisture in the mud and helps keep blistering down.
    1. Jim_Allen | Jan 12, 2008 12:14am | #4
      Double nice! Bob's next test date: 12/10/07
    2. DanH | Jan 12, 2008 12:38am | #5
      I've been using BIN, which seems to work well.
      1. dovetail97128 | Jan 12, 2008 04:44am | #6
        Same concept, something to seal the raw paper against the moisture in the mud. I have used rattle can lacquer, poly etc if that is all I had around at the moment.
        1. JerryHill | Jan 12, 2008 06:16am | #7
          spray adhesive here.....nice and tacky...also works good with plaster repairs where the scratch coat is exposed
  3. Jim_Allen | Jan 12, 2008 12:14am | #3
    Nice!
