drywall mud off fibergalss tub ?
Isamemon | Posted in General Discussion on December 22, 2003 10:54am
clean up . Drywall mud seams stuck a whole lot harder then normal to fiberglass tub.  Dont want to scratch tub, whats best trick for getting mud off, other then not getting it on to begin with ( I didnt do it)
  1. Zano | Dec 22, 2003 11:16pm | #1
    Wet the mud, let it soak for about a few minutes then use a piece of wood or plastic knife to "scrape" it off or use your fingernail.  Never use any metal utensil to scrape it!
  2. davidmeiland | Dec 23, 2003 12:52am | #2
    Had a situation once with adhesive of some type hard to remove from a fiberglass shower stall. It might have been the manufacturer's stickers or something. Called them and they said use silicone spray to clean and polish the thing. Guy that followed up on that said it worked like magic. Maybe call the manuf. for a tip.
  3. mike4244 | Dec 23, 2003 03:04am | #3
    Hot water , cover drain so mud does not clog it.
    mike
  4. HeavyDuty | Dec 23, 2003 04:14am | #4
    Is this the drying type or the setting type?
    If it's the drying type it's probably best to plug the drain and keep wetting it with water till it's washed away and settles on the bottom of the tub. Then scoop it up with something soft. A hand held shower head helps a lot. Resist the temptation of rubbing it off because it is a mild abrasive and it may dull the finish.
    If it's the setting type then you have to soak it till you can pop it off with a lateral push using your finger.
  5. WayneL5 | Dec 23, 2003 06:03am | #5
    I would avoid rubbing at all.  Let is soak as long as it takes till it comes off with just a rag.  If it's on a vertical surface you can lay wet towels over it.  Adding quite a bit of vinegar to the water will help.
Fast, Accurate Wall Framing
