Drywall on front porch ceiling
woolah | Posted in General Discussion on January 13, 2009 07:44am
We had a house built in 2000, using drywall on the ceiling of the front porch. Over the past six months, almost all of the tape has come off.  We’re wondering if we should get someone to re-tape it or pull it all down and go with something else.  If we re-tape, what should we look out for?
thanks
  1. cameraman | Jan 13, 2009 07:55pm | #1
    If this is a front porch that is open to the elements, including a screened in porch, Wrong uses of material.
    Rip out and replace or cover over with the proper material.
  2. DanH | Jan 13, 2009 08:01pm | #2
    At the very least it needs to be taped with "setting" type joint compound. (Stuff that must be mixed with water before use and hardens within an hour or so, without needing to dry first.) If the drywall is of the moisture-resistant variety then that may give you decades of additional life. (If it's not moisture-resistant then it will eventually fail, regardless of the type of joint compound.)
    Observe the drywall and decide if it's sagged between ceiling joists. If so, it probably should be replaced with the new fiberglass-reenforced drywall.
    God is REAL, unless explicitly declared INTEGER
    xxPaulCPxx | Jan 13, 2009 08:03pm | #3
    OK, standard canned responce to a first time poster:
    Please fill out your profile with your location.  Appropriate building methods are very different depending on where you live.  All advice given here is dependent on that information.
    Welcome to the forum!
    Tu stultus es
    Also a CRX fanatic!
    Look, just send me to my drawer.  This whole talking-to-you thing is like double punishment.
  4. Muttly | Jan 14, 2009 11:27pm | #4
    There is a housing complex in Detroit that did this, the drywall first lost it's tape, then fell on people. yrmv
Picture-Perfect Pergola
