A previously undiscovered use for the multi- faceted duct tape was recently placed into active duty inroute to jobsite. Always spilling coffee in a turn, a bad bounce tips the pop drink. Another day passes and nothing was done to remedy the situation when I glance down and see the roll of duct tape lying there in wait. Then in a moment of mad inspiration I reach down and grab the roll of tape and with a quick slap of the wrist put the roll flat side down on the engine cover of the van and voila’… a drink container is born, mobile no less. With the coffee sitting in the center of the roll, protected from tilt on all sides, I continue on into the morning light.
Prescriptive codes don't address the connection at less common angles, so base the connection off more typical ones using bolts, structural screws, blocking, and steel tension ties.
Rez: And the side of the roll is probably sticky enough that it helps keep it from sliding around.
Don
Good idea.
now thats american ingenuity Darkworksite4: When the job is to small for everyone else, Its just about right for me"
I dont really care what they do with this site as long as they have it , because I would sure miss funny stuff like this. How; the way it is , that sounded .
Tim Mooney
