durabond and vinyl corner bead
nomorecoffee | Posted in General Discussion on April 5, 2021 04:34pm
Doing drywall.  Was planning to set or first-coat vinyl corner bead with Durabond for strength like I’ve done before without issues.  This time I’m doing weird attic off-angle corners so looked into trim-tex magic corner and no-coat ultraflex and I see they both say not to use setting compound.  Looked into it more and found a Myron Ferguson article here that says to use bonding additive to make the compound stick to the vinyl.
Does all this apply to Durabond or is it a special case?  I though the whole point of this stuff was that it was rock solid and adhered well.
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
