I live in the No. CA Bay Area and I’m having trouble find suppliers of blue board for a skim coat plaster. Any one know of any reason why I couldn’t use backer board as a base for a plaster skim coat in my bathroom remodel? Seems like it sould key well. Any one know? Thanks.
Listeners weigh in on Brian’s haunted showerhead and ask questions about covering overhangs with trim coil, sealing air leaks, and how to partially finish a basement.
How to Install Cable Rail Around Wood-Post CornersRelated Stories
it'll do just fine..even superior... but the skim coat won't behave the same way it does on blueboard..
do a two coat.. brown coat and then finish...
Thanks. That's encouraging if I go that route. Do you know if I should use a specific brand of plaster or any add mixes since this will be for the bathroom and might get wet? Would you use the same mix for the finish coat as you did the brown coat? Which backer board is the best? I was thinking of using Durarock but I can get Hardibacker and one other brand at the HD. Any preference? Thanks again for your help.
Charles
charles,
i think you can get blue board from grabber in san francisco. give them a call 415-284-1870
Thanks, I'll try them. I've also since found of about some place in Oakland called Alta or some such. Still researching. Charles
