duroc instalation
| Posted in General Discussion on February 13, 2005 07:27am
what problems would be encountered if the duroc backerboard was installed with the smooth side out on a tile installation.
    Sphere | Feb 14, 2005 12:38am | #1
    ya have to install the tile wrong side out as well.
    Restoring, Remodeling, Reclaiming The Quality..
    1. FastEddie1 | Feb 14, 2005 01:09am | #2
      Yeah, and you set it with grout, then smear it with thinset.
      1. reinvent | Feb 14, 2005 01:52am | #3
        Sounds like one of them modern architects houses
    2. DANL | Feb 14, 2005 02:57am | #4
      No, those tiles are for the opposite wall!
  2. DANL | Feb 14, 2005 02:59am | #5
    Dontcha just love us smartazzes? To try to be serious, I don't think it would matter a whole lot. Maybe someone who does more tile than I do can give you a straight answer.
    EricPaulson | Feb 14, 2005 03:39am | #6
    Other than getting razzed here..............none.
    Don't take my word for it though. Put a little thinset on the board, let it set up and try yo scrape it off.
    Eric
    [email protected]
  4. bkhy | Feb 14, 2005 05:01am | #7
    no problem
    1. ramboOremods | Feb 14, 2005 05:40am | #8
      Yea,no problem in fact better! leaves a smooth plane for setting .
      The mastics and thinsets don't care if it's smooth or rough,If your tiler don't like it don't use him next time,Tell Him! what should be further front in your mind is hang that stuff so your fasteners are set behind the surface,so as not to interfere with the bedding height,this is why I use galv ring shank nails,and take care not to beat it back so much you "cherry-up"(beartrack) the backer,It will cause a weak hanging point...
      (no charge this time)SCRIBE ONCE CUT ONCE!
Grout-Free Shower Panels
  • A Grand Rescue on the Coast
