dustless drywall cutting power tool
| Posted in General Discussion on June 13, 2007 08:50am
Hi,
I am looking for a tool that I saw a guy from a flood restoration company use to cut and remove drywall. It was a power tool like an angle grinder but it had a vacuum attatchment and when cutting the drywall to remove it, there was no dust. Does anyone know of such a tool and where I could fine one?
Paul
  1. Danno | Jun 13, 2007 02:54pm | #1
    Maybe you could hook up a hose to a Rotozip. Those don't make a whole lot of dust anyway--at least not like a circular saw! Even reciprocating saws don't make a lot of dust, but it's hard to control depth (bummer when you cut a wire!).
      IMERC | Jun 13, 2007 03:47pm | #4
      use a 5/8 to 3/4" long blade and cut on the perpendicular...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
  2. roofguy | Jun 13, 2007 03:11pm | #2
    I recently had to make a long horizontal cut through old Z-Brick and 1/2" drywall to install a new countertop in my existing kitchen. I used my 4 1/2" angle grinder with a thin kerf diamond masonry blade. I carefully duct taped the inlet hose of my shop vac to my grinder close to the exit end of the blade, allowing me to have both hands to control the cut. Sucked up all the dust!! Fast, low-teck, and effective!!
  3. zift | Jun 13, 2007 03:46pm | #3
    dustmuzzle.com
  4. kate | Jun 13, 2007 05:29pm | #5
    My rotozip has a vac pickup attachment - that would work.
    Edited 6/13/2007 10:29 am ET by kate
  5. joeh | Jun 13, 2007 05:51pm | #6
    Not much dust cutting wet drywall. :)
    Joe H
  6. notascrename | Jun 14, 2007 01:07am | #7
    Take an old sawzall blade, chuck it up in the recip., and roll the motor around till it's at full extension. mark the blade at 7/16th's or so long, cut it off with the side grinder. mark wall and follow the yellow brick road. cuts over studs and won't cut wires. creates no dust. Jim
  7. timkline | Jun 14, 2007 03:23am | #8
    i hate to even share this..........
    http://www.kett-tool.com/webpages/tools/saws/KSV-432.htm
    absolutely, the balls.......
    carpenter in transition
    1. PaulTL | Jun 14, 2007 05:32am | #9
      Thanks for the website, that looks like the tool.As for the other suggestions I want the tool to cut through interior plaster walls and the blades I use with a recip saw get chewed up with the plaster and metal lath and I do think that a rotozip will work either.
