DWV 90 degree turn?
JohnCA07 | Posted in Construction Techniques on October 2, 2002 01:31am
I’m installing a new main sewer line to my septic tank (due to remodel) and the new line  needs to take a couple of turns to meet the tank.  I have two concerns, which are, what should I be using to make the 90-degree turn and should I be running a 1/4 †or 1/8’ drop with the 4†pipe?
The new line is 4†PVC and follows this route:
  1. Exits side of house (3 feet)
  2. 90 degree turn
  3. Straight run (30 feet)
  4. 45 degree turn
  5. Straight run to septic tank (20 feet)
Thanks for your help.
-John M
  1. allaround | Oct 02, 2002 02:52am | #1
    Do you have to stay close to the house for that first 30 ft?  If not, how about this?........on the 3 ft stub coming out of the house, put a 45, run about 10 ft and turn another 45.  Now you've made your 90 with a much larger radius.  Run parallel to the house about 30 ft, then turn 45 and run another 10 ft to the septic tank.  If you ever have to run a sewer rod through the pipe, it'll be easier to get past 3-45's than a 90 and a 45.  Use a minimum of 1/4" per ft slope, but no more than 1/2" per ft.
    Edited 10/1/2002 7:54:34 PM ET by allaround
    1. brownbagg | Oct 02, 2002 05:38am | #2
      you need to do away with the 90 and try to go from three feet staight to tank. also watch out for you turn for every amount( i cannot remember) of turns you must have a cleanout. The 90 must be a sweep 90 not a vent 90
