Eave Framing detail.
steveinpa | Posted in Construction Techniques on November 8, 2006 04:31am
I am building a house with the following eave detail, a 15/12 rafter with a lower sloped kicker sistered on top to create a curved roof eave.  http://sitebuilder.verizon.net/trellix/sitebuilder/f_edit_page.html
The question is about the 3/4″ Plywood rough fascia shown.  I will have the kickers tuned up with a string line so they’re in alignment.  Is the 3/4″ plywood rough fascia necessary?  the top edge formed by the kicker will be straight and true, the bottom could be trued with the 1x_ soffit piece.
  1. KirkpatrickFramer | Nov 08, 2006 05:16pm | #1
    Hard to answer your question, your link is a 404.
    I always use a subfascia with a closed soffit. It allows me to be a little sloppy on the tails. I use a nailer on the wall and lookouts along with the subfasia which gives a good strong nailing surface for everything.
    But I can't imagine ripping plywood for a subfasia.
    1. Piffin | Nov 08, 2006 05:25pm | #2
      Nor can I . #4 pine is stronger, straighter, and longer.
    2. steveinpa | Nov 08, 2006 05:28pm | #3
      the subfascia here is a little over 1' wide.  Do you ever with 1x_ material?
      1. KirkpatrickFramer | Nov 08, 2006 11:34pm | #5
        I've done it with 1x but the quality here isn't that great and we use hardie soffit so the 2x gives a bigger nailing spot.
      txlandlord | Nov 08, 2006 08:31pm | #4
      Yep, same thing here......Texas typical.
      Yea....what?
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
