edge gold osb off gas over radiant heat?
driftwood | Posted in General Discussion on April 6, 2008 07:44am
due to cost i was going to scrap the wood floor thing and go with that portland new age stained OSB look to me i think it looks great ..
but i was wondering if the offgas of the glues heating up from the radiant heat under the stuff would make me sick …
this is my first radiant heat show any suggestions would help thanks
  1. rez | Apr 07, 2008 03:50pm | #1
    bump
    Click here for access to the Woodshed Tavern
    1. driftwood | Apr 08, 2008 05:12pm | #2
      try in the morning
      bump
      1. rez | Apr 08, 2008 05:46pm | #3
        Maybe try rewording the question with more detail,
        and descibe exactly what the 'portland new age stained OSB look' product is.
        Cheers
        1. VaTom | Apr 08, 2008 08:16pm | #4
          Or just provide ample air changes.  Pretty much solves outgassing of any sort.
          I don't have a clue about the product either.  But outgassing is normal for about anything you bring into the house.PAHS Designer/Builder- Bury it!
      rjw | Apr 08, 2008 09:19pm | #5
      Rez, I believe that when you view a message, your cokkies let it "drop" on the list that you see.  For folks who haven't viewed it, it stays at the top, so I wonder if your well intentioned bumps actually do anything.
      Remember Mary Dyer, a Christian Martyr (Thank you, Puritans) http://en.wikipedia.org/wiki/Mary_DyerMay your whole life become a response to the truth that you've always been loved, you are loved and you always will be loved" Rob Bell, Nooma, "Bullhorn"
      1. rez | Apr 08, 2008 09:34pm | #7
        A large bulk of people just view off the Recent Discussion and the most recent in the other folders. Place has gotten too big to catch all the threads.
        Bumping resubmits a post to the beginning of the process.
        I recall a number of times where a post was bumped a couple times before Piffin or someone else that cares enough to respond to a query saw the post, saying they had never seen the post before.
        Anyone that takes the time to post a question here should at least get one response even if it's just an acknowledgement.
    rjw | Apr 08, 2008 09:25pm | #6
    First: research OSB and outgassing - witha quick look it seems there are at least two types of adhesive used with different levels of outgassing, and that there are UF free OSBs becoming avaialable.
  3. IdahoDon | Apr 09, 2008 12:34am | #8
    I wouldn't think it would be a problem unless someone is extra sensitive to such things.  Keep the home well ventilated and don't lose any sleep.
    1. driftwood | Apr 09, 2008 08:48am | #9
      o i luv the bump, at first i didnt know what it ment but , hay look I posted fresh in the morning pacific time and got some nice replys thank you all so very much..i will be having a HRV or ERV heat or energy recovery unit installed so there will be a constant air exchange ...i was just wondering if anybody has ever done this i.e place OSB over infloor heating systems and if they had a gluey smell...ive seen some of the nicest floors done inexpensivley by sanding and staining OSB with a nice cherry stain, the chips pick up a nice uneven stain coat where the edges of the wood chip hold darker stain...looks very good and is quite durable if sealed properly...if i could find a pic i would send it out
      1. rez | Apr 09, 2008 09:06am | #10
        sorry driftwood. Seeing you had been around since '05 I took for granted you would have known what the bump was without my making the normal copy/paste explanation.
        My bad.
        1. driftwood | Apr 09, 2008 09:48am | #11
          totally all good razi just learned what the bump was a year or so back when i was lifting this house for a new foundatiion thanks again for the bump up to the topnice worktj
A Practical Perfect Wall
  • The New Old Colonial
