edge guide on skilsaw to rip lumber
woodysawdust2 | Posted in Construction Techniques on June 11, 2006 10:59am
recently, i had to rip some 2×4’s in half, and didn’t have my tablesaw with me..I’ve gotten used to using my fingers to clamp on to my skilsaw table to use as an edge guide for ripping, but i don’t know how many times i’ve ended up cursing at the number of splinters I accumulate form the rough edges of lumber.. I looked around my tool box for some kind of small clamp i could attach to my sawtable, and came across my set of stair gauges.. perfect!! just clamp the stair gauge onto the front edge of your skilsaw tableat the appropriate distance from the blade, or use two to clamp onto the front and back edges to keep the saw aligned..
  1. CAGIV | Jun 11, 2006 11:02pm | #1
    you could also by a rip guide for about 10 bucks ;)
    Team Logo
  2. Stilletto | Jun 12, 2006 12:21am | #2
    In a pinch I've used a pair of vice grips,  they work great for smaller rips up to about 4 inches.
    I only golf on days that end with a "Y".
  3. blue_eyed_devil | Jun 12, 2006 02:33am | #3
    A chunk of wood is faster. My pencil is always handy; it works fine.
    I wear gloves and I rarely get those slivers but I do remember them from my earlier "bare" years.
    blue
    1. KirkpatrickFramer | Jun 12, 2006 03:13am | #4
      those stair gauges are the trick. I've found a ton of uses for them, including what you said. You can also use 'em to kick your saw bevel up a few degrees and keep it consistent, i.e. 56 degree bevels on rafters etc...
    2. woodysawdust2 | Jun 13, 2006 08:55am | #5
      thanks, guy..i like the one about tilting the table over 45 degrees, too..
A New Approach to Foundations
