I have two Makita circular saws, one has an electric brake while the other spins on forever. They are 5007NBA and 5007NB. Can a brake be put on a saw. The housings are identical. What makes them stop in the first place.
Listeners write in about HVAC company consolidation and stains from supply lines and ask questions about Larsen trusses and insulating stucco houses.
SawStop's Portable Tablesaw is Bigger and Better Than BeforeRelated Stories
The "brake" is a surge of current applied to reverse the motor. Sounds easy, but it's not.
*PhillThanks for your reply. I stopped by an electric/tool supplier on the way home tonight and ask the same question. They thought that a different switch might be used at first but went ahead and called Makita. The rep there said something about changing the field, magnetic I guess. Anyway there is more to it than a simple switch. I guess you never know unless you ask.
*to really find out, you need the exploded view and parts list for both and then you can see which parts are changed.
*Just use your thumb.
*It's getting to short and the customers are complaining about my choice of stain color.
*Don't ya hate that ?Whiners.And after all you donated to the job.b : )
