Having a limited number of spaces for additional circuit breakers in my entrance panel, I’ve thought of using our electric dryer outlet to power my planer and perhaps my table saw. Figure I’d buy another dryer pigtail and wire a suitable receptable to it.
Any thoughts, opinions, suggestions?
Chuckdua
I did that in my last house. Never had a problem, but the dryer wasn't ever going the same time I was in the shop. I don't think it was code, I believe a dryer, stove, and AC units have to be dedicated. So I just unhooked all my wiring when I sold the house.
I'm interpreting this to mean you'd unplug the dryer, basically use a 220 extension cord, as it were. Friend of mine did this to run his welder out back; his wife didn't like it, though. Every time she wanted to use the dryer, he was welding something.
Sure you can. So long as the circuit is up for the load, anyways. Dryers are generally setup for 30amp, but sometimes the guage is on the low end in terms of voltage drop. Just something to consider with cord length and such.... Your tools probably do not draw that much compared to welders or compressors.
I have made short adaptor cords to plug into 3 different 220v recepticle styles. I try to setup all my 220v stuff with identical locking plugs on the 'appliance' end so that they all can use the same beefy extension cord that I assembled. Then I have the short adaptor cords on the other end for versatility. This setup also comes in handy when you want to use a welder or compressor (or whatever) at another worksite.
Of course, you could also mount a new subpanel.
