electric motor rotation direction
FastEddie | Posted in General Discussion on June 14, 2008 03:44am
I need to replace the blower motor in my home a/c unit.  Looking at grainger, I think I have found the right replacement.  But I’m not sure about which way the new motor spins.  The description says “CCWLE”  Which way is that?
“Put your creed in your deed.”   Emerson
“When asked if you can do something, tell’em “Why certainly I can”, then get busy and find a way to do it.”  T. Roosevelt
  1. VaTom | Jun 14, 2008 03:58pm | #1
    Page 7 in the newest catalog of theirs that I have:  counterclockwise, lead end.
    PAHS works.  Bury it.
    1. FastEddie | Jun 14, 2008 09:00pm | #4
      Ok, here's another test.  The name plate on the existing motor shows 825 rpm.  Almost all the ones at Grainger are 1650 and sell for about $100.  they do have one at 825 rpm but it sells for over $300.  I suspect that the fan is designed to operate at about 800 rpm, so how bad would uit be to use the faster motor?  This is for the fan in the condensing unit, not the inside air handler."Put your creed in your deed."   Emerson
      1. McMark | Jun 14, 2008 11:13pm | #7
        Bad.  But you could swap out sheaves on the motor to one with 1/2 the circumference, and still be ahead money wise.
        1. FastEddie | Jun 15, 2008 12:19am | #8
          Nope.  The fan blade is mounted on the motor shaft."Put your creed in your deed."   Emerson
            Sphere | Jun 15, 2008 01:05am | #9
            Just cut off every other blade, then the fan will only do half as much!Spheramid Enterprises Architectural Woodworks
        PeteDraganic | Jun 15, 2008 01:10am | #10
        My biggest fear with the faster motor would be balance issues and potential breaking apart.  Doubling the speed would assert considerably more force on the blades.
        I refuse to accept that there are limitations to what we can accomplish.        Pete Draganic
          jarhead2 | Jun 15, 2008 01:30am | #11
          If it spun too fast use it as a helo to get to work!
          “Some people wonder all their lives if they've made a difference. The Marines don't have that problem.”                Reagan....
            PeteDraganic | Jun 15, 2008 01:36am | #12
            Or a combo fan and wood chipper.
            jarhead2 | Jun 15, 2008 01:39am | #13
            Don't you need a kicker or a trolling motor?   LOL
      3. caseyr | Jun 15, 2008 01:46am | #15
        To use the cheaper but faster motor, just tap into some 30 hz electricity...:)I am guessing that a contributing factor for the higher cost of the slower motor is lower demand, more difficult to build with more poles, or perhaps is built in the US rather than China or elsewhere. From a motor supplier website:"A two-pole motor will operate at 3,600 RPM unloaded and between 3,000 and 3,450 RPM under load. Such speeds are commonly found in pump applications, such as submersible pumps, sump pumps, pool or water recirculating equipment. Another typical application is small ventilating fans. To the untrained ear, two-pole motors appear to need servicing because they sound somewhat noisier when running. This is principally due to the higher RPM, and as a service technician, you "should be aware of the different “normal” sounds a motor makes that are related to speed."Six-pole motors run at 1,200 RPM unloaded and between 1,050 and 1,175 RPM loaded. They are often used for air-handling equipment, direct-drive applications, window fans, furnace blowers, room air conditioners, heat pumps, residential garage door openers, and other equipment."As you can imagine, lower mechanical speeds often result in quieter designs, which makes an eight-pole motor well-suited for many residential applications where noise is a factor. These motors operate at 900 RPM unloaded (between 800 and 875 RPM loaded) and are being used more extensively today in room air conditioning, outdoor heat pump, and residential garage door openers."A less common design is the 12-pole motor. This motor, which runs at 600 RPM unloaded, is used in washing machines and other equipment that require a slow cycle."Here’s the important point to remember: when replacing a motor, you must select a replacement with the same number of poles as the original. Changing, say, from a four-pole to a six-pole design, the speed mismatch is likely to create significant problems."http://www.aosmithmotors.com/html/motorDoctor/Understandingmotorspeed.htm
        Edited 6/14/2008 6:48 pm ET by CaseyR
  2. Chucky | Jun 14, 2008 04:09pm | #2
    VaTom already answered so i'm really only posting with this link to an acronym dictionary
    http://acronyms.thefreedictionary.com/CCWLE
      jarhead2 | Jun 14, 2008 04:43pm | #3
      I looked it up too and found it but what exactly does it mean?  Looking from the "back" of the motor it is CCW? I am assuming the lead end means back or the rear of the motor.
      CCWSE, must mean looking at the shaft end it's CCW?
      1. Chucky | Jun 14, 2008 09:33pm | #5
        I really have no idea.  I did google "Counterclockwise Lead End" though and came up with this site which explains it.
        http://www.emotorstore.com/electric_motor/faq.asp
          jarhead2 | Jun 14, 2008 09:43pm | #6
          Looking at that link, lead end would be looking at the rotation from the opposite end of the shaft or the back of the motor.
          SE or shaft end is looking at the rotation from the shaft end......
          Cleared that mystery up!
          Edited 6/14/2008 2:44 pm ET by jarhead2
            maddog3 | Jun 15, 2008 01:45am | #14
            FWIW, motor rotation is always viewed at the end opposite the shaft, and "normal" rotation is CCW ..... just ask your guys at workthis CCWLE hooey must be some idiotic jargon for the diy bunch or maybe the HVAC crowd since they like to keep things mysterious, or maybe its a double shaft motor, or .....I dunno :/.
            jarhead2 | Jun 15, 2008 01:48am | #16
            I'll do that this week when they are there. Bastiges have bankers hours!
            How'd that wire work out by the way?
            maddog3 | Jun 15, 2008 02:34am | #17
            bankers hours ?? must be nice,
            I just walked in the door
            6-10s until end of July ..your wire is safe and cooling off until Winter comes back, I tried it in the cold frame for an early start on the garden stuff but it's too hot to let it run without a thermostat, the ground warmed up to 91º while the outside was in the 30s at night... so my original plan of a heated bird feeder is still in the works, and it's probably going to be overdone as usual.. since I have a digital MIN/MAX thermostat for it turn it on at 34º and off at 40º , I'll put an indicator light on it so I can watch it blink at night while I'm just sitting here..most likely end up costing around $500 by the time I finish with it ;)new lumber
            new tools
            trencher rental
            beer
            whisky
            aspirin
            new cable for the electric
            about 50 man hours of my plentiful free time
            maybe a 1000 watt dimmer........ in case the thing starts smoking.
            jarhead2 | Jun 15, 2008 02:55am | #18
            ROAR!    Let me know if you need something that we may have that might rectify the situation!
            new lumber new toolstrencher rentalbeerwhiskyaspirinnew cable for the electricabout 50 man hours of my plentiful free timemaybe a 1000 watt dimmer........ in case the thing starts smoking
            Sounds like one of those commercials........
            maddog3 | Jun 15, 2008 03:44am | #19
            Eric, your generosity is rather overwhelming, but very much appreciatedanyway I got all sorts of paraphernalia, none of which I really need or will ever use, I'm sure I can cobble something together to make the project so complicated,
            I won't be able to fix it once I build itbut I could use a 3/4 HP resistor for a KB Dc drive .... . 015 ohms ought to do the trick .....that right there is meant to be taken in jest.....
            jarhead2 | Jun 15, 2008 04:35am | #20
            Brother, that sh!~d is german.......  I know you are janking but i am going to ask the guys about it!
          7. User avater
            maddog3 | Jun 15, 2008 01:39pm | #24
            the things are about $1.7threeforty, and the motor shop in town looked at me like I had lobsters crawling outta my ears when I inquired about one.. yet another small town benefit.
          8. User avater
            jarhead2 | Jun 15, 2008 02:57pm | #25
            LOL!!!!!
            I'm sending an e-mail now to someone in the department, we'll see what pops up.
          9. User avater
            jarhead2 | Jun 15, 2008 03:02pm | #26
            Is it   .015 ohms?   or    15ohms?
            The.......  on your post got my eyes jacked up  but I figured if you meant just 15 ohms the "0" wouldn't have been there.
            Line voltage?
            Motor voltage?
            Edited 6/15/2008 8:09 am ET by jarhead2
          10. User avater
            maddog3 | Jun 15, 2008 04:39pm | #27
            don't you have anything better to do ??LMAO.........
            HOLY SHID the winds just cranked up to around 60mph here checked the weather and it's bad.
          11. User avater
            maddog3 | Jun 15, 2008 05:18pm | #28
            whew that was fun !!
            just Donder und Blitzen nowanyway it is .015.
          12. User avater
            jarhead2 | Jun 15, 2008 06:22pm | #30
            whew that was fun !!just Donder und Blitzen now
            LOL, you made me look that up!  I was thinking snow as in the dang reindeer!
            Thunder and lightening........
            Bad huh?
          13. User avater
            maddog3 | Jun 15, 2008 06:46pm | #31
            real dark real fast, very strong winds, cooled off a bit down to 65ø and now the sun is outwith another storm heading out of Chicago right now.
          14. User avater
            jarhead2 | Jun 15, 2008 10:01pm | #32
            Are they coming across the US or effects of the lakes?  Just curious.
          15. User avater
            maddog3 | Jun 15, 2008 10:15pm | #33
            it looks like a little of both today, that earlier one had the feeders hanging horizontally some big storms moving across central Illinois , just what they don't need
            , and we've been surrounded by tornado warnings in other counties all week.
          16. User avater
            jarhead2 | Jun 15, 2008 11:02pm | #34
            Stay safe!
          17. User avater
            maddog3 | Jun 15, 2008 11:31pm | #35
            OK.
  3. USAnigel | Jun 15, 2008 06:04am | #21
    Whats wrong with the existing motor? might be a simple fix? check with the HVAC co to see if they might help with a replacement.
    1. FastEddie | Jun 15, 2008 06:24am | #22
      Existing fan motor is about 15 yrs old.  Last night it started squealing, loud enough that the neighbors came over to see what was happening.  I pulled the cover off the a/c unit and noticed that the fan does not spin easily.  I think the bearings are shot in the motor.  it still spins, and the unit still pumps cold air into the house, so I think i have time to wait until Monday to go to a supply house and get a repolacement.  I don't see a need to pay for a weekend service charge in the heat of the summer."Put your creed in your deed."   Emerson
      1. USAnigel | Jun 15, 2008 06:27am | #23
        Hey spend $20 on new bearing, quick and fairly easy.
      2. VaTom | Jun 15, 2008 05:32pm | #29
        Condensing units I have no experience with, no ac needed here.  Changing speed isn't anything I'd try.  Nigel's got the cheap ticket though, new bearings.  BTW, I've never found Grainger particularly inexpensive.  If you want bearings and encounter a problem, yell.  Short-term, can you get to the bearings to try squirting lubricant on them?
        What used to be Dixie Bearing is now called Applied Industrial Technologies here.  They keep my machinery happy.  At least one in Richmond.  No idea how long your bearings last, but I keep a spare set on hand for the tools here that are prone to bearing problems.  IIRC, their stock is accessible on-line.
        Somewhat related, my heat pump water heater refused to function this year (only used when the house is consistently over 70º, provides 50% of our dehumidification needs this time of year.  Asking the company that bought the company that bought the company that manufactured it came up with: either the Taco pump or the compressor has a problem.  Hard to believe that I could get such good info so easily.  Compressor's beyond me, but I can take a pump apart.
        It's stiff.  Too stiff?  No idea, but that pump's no longer available.  Today another identical (obsolete, 20yr old) HPWH is being delivered.  Beating the bushes sometimes is very effective.
        Rather than just install the new (old) HPWH, I'll take the pump guts out to test the old unit.  If it works, the search is on for pump guts, that I've been told might still be available for ~$75.
        Wanna know why I built a passively cooled/heated house?  LOL  Now if I can just get the dehumidification that way (passive)...   Hey, a test is in the works.  Fewer of these aggravations makes for a better life.  Machinery never breaks when you don't need it.  PAHS works.  Bury it.
A New Approach to Foundations
