electric motor runs both ways
edwardh1 | Posted in Tools for Home Building on November 18, 2003 09:36am
Is it bi-electrical?
Background- I have my father in laws ’60 era floor mounted 9 inch disc and 6×48 inch belt sander. It has a Dunlap 1/3 HP split phase (ball bearing!) motor. I got a drive belt and hooked it up today.
When you turn it on, each time it runs the opposite direction from before. No i have not been drinking (not today).
Anyone ever heard of this? two wire 110 volt. no visible capacitor.
I am not a motor expert but have never heard of this?
  1. JohnSprung | Nov 18, 2003 10:06pm | #1
    Squirrel cage motor run windings will work either direction.  It's the start windings that determine which way it goes.  Years ago I had one with bad start windings, and I was able to start it either direction by spinning it with a pull cord before hitting the switch.
    If you want to use this machine, probably best to take the motor to a rebuilder to see what it needs rather than taking a chance on frying something.
    -- J.S.
  2. OneofmanyBobs | Nov 18, 2003 10:48pm | #2
    Sometimes there is a start winding and a centrifugal switch on the small motors.  If the switch is bad, the motor doesn't get the starting kick and can go either direction.  You might be able to take off the end bell and clean the switch.  For all that work, I'd just buy a new motor.  Its quick and safe, unlike a 40 year old motor.  Sears sells them.  So do most any tool or electrical supplier.
    1. edwardh1 | Nov 18, 2003 10:50pm | #3
      whats odd about it is that it is repeatable, always goes the other way.
      thats no good with directional sanding belts tho
      1. brownbagg | Nov 19, 2003 12:05am | #4
        there is nothing wrong with the motor. A motor is just magnet and winding. If the magnet is just off one side when energy applie it will turn to the closes magnet, that is the direction the motor runs. I alway just spin the disc before turning on the power. They really nothing wrong it just life,. But using this trick I also made a motorcyle run backwards.
        The best employee you can have but you wouldn't want him as a neighbor " He the shifty type"
        BillHartmann | Nov 19, 2003 01:17am | #5
        I suspect that this motor was taken from some other application and has auto reverse built into it.
        Off the top of my head the only thing that I can think of that uses this kind of motor are garbage displosals. But those are built in and don't have standard frames.
        What does the label on the motor say?
        1. edwardh1 | Nov 19, 2003 03:47am | #6
          Dunlap 1/3 HP ball bearing split phase 6.2 amps 110 v 1963 0r 1968 can not read it
          really odd i tried it several more times and it does not always reverse itself. that is some times it runs twice when starting in the same direction
          it also has low starting torque
          really strange
          no this is not a test
          1. TKanzler | Nov 19, 2003 04:21am | #7
            The centrifugal switch or the start winding itself is bad.  It could also be a loose connection in the junction box.  If instructions for reversing the direction of rotation are on the motor, or under the j-box cover, the two leads that you reverse (or swap) to reverse the rotation are the start winding leads.  Check for tight connections.  You can also use an ohmmeter to check the continuity of the start winding (remove at least one of the leads).  A small motor like that will typically have a couple of ohms DC resistance across the start winding, if there is continuity through it and the start switch.
            You can also blow out the centrifugal switch through the openings in the end bell with compressed air, assuming it's an open frame motor.  With such motors on wood equipment, most of the time when the start winding isn't working it's because there's wood dust in the switch.  Some of them are pretty crude items (old Westinghouse fractional hp motors have particularly crude switches, IMO).
            FYI, a split-phase motor is essentially the same as a capacitor-start motor (technically, a cap-start motor IS a split-phase motor), but without the capacitor.  They have lower locked-rotor and pull-up torque, and are used in applications requiring low hp and light starting loads.  Compared to a capacitor-start motor, a split-phase motor will have wimpy starting torque, but if the start circuit isn't working, if it moves at all it will have very very slow starting until it gets a bit of speed.Be seeing you...
  3. CarpenterPJE | Nov 19, 2003 06:34am | #8
    Sounds like a "Democrate" motor, always changing diretion!!
    Oh Ship, here it comes!!   I see Bob Walker storming this way!!
    Edited 11/19/2003 7:37:00 AM ET by CarpenterPJE
  4. MarkCadioli | Nov 19, 2003 12:48pm | #9
    no it's not bi electrical
    it's Bi Polar  ( sorry....couldn't resist )
    regards
    mark
     Quittintime
