Electric Radiant Floor Heat
user-237853 | Posted in Energy, Heating & Insulation on October 10, 2002 09:56am
Hello,
My wife and i are considering making an offer on our first house, a 900-square foot bungalow built in 1900.  To make a long story short, the living room has a beautiful brick pedestal and chimney that would be perfect for a wood-burning stove, but currently ensconced upon it is an ugly and probably unsafe natural gas heater.
We would like to install a wood-burning stove, but would need another “primary” form of heat for resale purposes as well as to keep the pipes running and the dog happy when we’re not home.
I have stumbled across several websites for people advertising “easily retrofitted” radiant electric floor heat systems. Does anyone have experience with these? Will they put off enough heat to keep the pipes from freezing (we live in Helena, MT)? The floor in the house will need some work because of subfloor problems, so I’m going in there anyway if we buy this house.  And the previous owner bought a good replacement hardwood floor but did a poor job installing it, anyway.
But back to the main topic: radiant electric floors. What’s out there?
  1. TLRice | Oct 11, 2002 02:00pm | #1
    About a month ago, someone named Jeff asked the same question. My response to him was:
    "I have installed two different electric resistence floor
    heating systems in my home. One is a cable imbedded
    in a mud bed under tile in a second floor bathroom.
    Made by Maxxon, sold under the trade name of Infloor
    Heating Systems. In an area of about 80 sf, the 800W
    floor heat provides enough heat to keep the room
    warm. Operates with a room air thermostat controller,
    with an internal floor temperature setting. No
    programming, on/off and temperature control. This
    works well in this installation because at night when
    the furnace is on a "setback" temperature, the
    bathroom floor is nice and warm, wonderful for bare
    feet in the middle of the night.
    The other systems that I have installed in my home is
    by NuHeat which has the wires imbedded in a fibrous
    mat, installed in a thin layer of thinset. The wattages
    are less, per square foot (see their website for sizes
    and ratings), they are less flexible for installing in odd
    shaped areas (but can be custom ordered). The
    controller works bbased on floor temperature alone, but
    can be programmed for 4 (I think) different "modes"
    plus a manual control setting.
    I like them both. I like the programmable controller over
    the non-programmable one, but the air temperature
    thermostat is nice for the reason stated above. The
    wires have to be clipped to the floor by some means
    and was a pain screwing clips into Durock over
    plywood. Also for the cable type, a self-leveling type of
    concrete like Thermafloor or Gypcrete (also by Maxxon)
    is recommended unless you are good with a trowel."
    To your question, "Will they put off enough heat to keep the pipes from freezing (we live in Helena, MT)?", probably, but depends on the construction of the house.
    Tim
Choosing a Paintbrush
  • The New Old Colonial
