Electric radiant Heat – in ceilings
| Posted in Energy, Heating & Insulation on February 11, 2003 09:00am
All
Would you please provide some comments on electric radiant heat in ceilings.  I am looking at a home that has electric heat throughout the entire house – as well as forced hot water by oil in  most rooms.  The bedrooms only have electic heat.
There is no attic – the second floor bedrooms all have cathedral ceilings.  The house was built in 1983. and is in Boston, MA.
I was wondering….
1) what is the impact of having heat in the ceiling/roofing structure to the live span of the roof shingles etc.  It has it original roof.
2) One of the bedrooms and one bath have no heat during the home inspection.  The other bedrooms warmed up but after 3 hours- no heat output was detected.
3) Any limitations/concerns regarding 1983 technologyn for electric heat. e.g proper wiring, expected maintenance, what could could wrong.
4) Does ceiling based radiant heat makes sense?  I guess I would have less of a concern if were floor radiant heat
I fully expect to replace the remaining electric with forced hot water baseboard heat but I didn’t want to do this right away.  Just looking to tap others experience and knowledge to plan out rough plan and timeline.
Thanks in advance for any thoughts you may have.
S
  1. DaveRicheson | Feb 12, 2003 01:27am | #1
    The few that I have seen present two problems, (1) heats in the wrong place, up, and wants to stay there,(2) it is expensive! The last guy I talked to that had it cut his electric bill by almost two thirds after installing a heat pump forced air system, and we are in a milder climate and have one of the lowest electric rates in the country.
    Dave
    1. sregent | Feb 12, 2003 05:09am | #2
      Thanks for the reply.  I appreciate it
      Shawn
Rescuing Old Hardware
Whether it’s already in your house or picked up at a flea market, vintage hardware almost always needs help.
