4″x4″ electracal box
blank cover
one side of the blank cover has embossed in it “Under side”
huh?
it fits the same either side up
am I missing something?
blank cover
huh?
The Diamondback 701 Vest offers an alternative to traditional tool belts, with adjustable features and the ability to accommodate both clip-on and traditional tool pouches for different tasks.
isn't the mfrs. name on the other side?
I have seen 4x4 box covers which although they will fit with either side out, they work best oriented in one direction.
This "work better in one direction than the other" phenomena is caused by the angle the screw slots are cut - when you tighten the screws the box cover pulls in toward the screw shanks, if you flip the cover it wants to walk away from the screw shanks as the screws are tightened.
Nice of them to mark it if this is the reason.
Jim
My thinking was that the plate is stamped so one side has a more rounded edge which should face the outside so nobody would get a cut if they accidentally rub their body part on it.
But then after reading about the screw thing that makes more sense than what I originally thought.
Or maybe they just got tired of people calling them up and asking them which side went out.
What about when you use it on a ceiling box?
SamT
"Out" is the opposite of "in", "in" is always the box.
Unless it is a 240v circuit in the southern hemisphere, I think that's the exception?? Can't remember.
Jim
I was told that because the cover is stamped a lot of them have a relatively sharp edge. If this edge is pointed out, away from the box, it poses a small, but real, scratch hazard. When handling a lot of these covers I find the skin on my hand has been sliced up. Never deep enough to draw blood but it can be annoying and the deeper ones sting a bit when eating an orange or if I get PVC cement into them.
Flip the cover over and the sharp edge rides outside of the box so it doesn't pose a hazard to the insulation on the wires.
The hooks where the screws go should be pointed down. Idea being that if the screws loosen the cover should remain in place, held by gravity. If the box is laid flat the position of the hooks doesn't matter much.
