Electrical boxes in brick veneer
mwgaines | Posted in Construction Techniques on April 9, 2007 01:19am
I’ve got a mason scheduled to install brick veneer in a little over a week. This is part of a major remodeling job. I haven’t roughed in the wiring yet and I’m puzzled about how to properly mount the electrical boxes for the porch lights and exterior receptacles. I know there will be an air gap between the brick veneer and sheathing, but I can’t be sure exactly how to mount the boxes so that the cover plates and/or fixtures will fit properly when all is said and done. What’s the best way to go about this?
New knowledge is priceless.
Used knowledge is even more valuable.
    BillHartmann | Apr 09, 2007 01:52am | #1
    You might want to look at these products.
    http://www.aifittings.com/arliprod5_b.htm
    http://www.aifittings.com/arliprod6.htm
  2. brownbagg | Apr 09, 2007 02:03am | #2
    you give the mason a metal box and he mortar it in the brick
    1. dude | Apr 10, 2007 08:19am | #3
      the box is hanging from the wall  on a length of wire  so you tell the mason  where you want it to end up & he takes care of installing it in the  brick work
      ps: remember the doorbell wires , hard to get in later
    2. IdahoDon | Apr 11, 2007 10:14am | #6
      What you said.
  3. dude | Apr 10, 2007 08:26am | #4
    the boxes are normally hanging from a length of  wire approximately in the area  where they will finally end up so you just tell the mason of your intended final location & he takes care of the rest
    1. mwgaines | Apr 11, 2007 02:36am | #5
      Ok, thanks guys.New knowledge is priceless.
      1. dedubya | Apr 11, 2007 02:07pm | #7
        Don't worry mw things will work out fine
