Electrical chase
kleinchen | Posted in Construction Techniques on November 25, 2008 04:42am
Hello all,
I need to run surface mount wiring along a couple brick walls and would like to use a wire chase to accomplish this. I’ve been looking at different set-ups, including no-frills metal conduit and wiremold set-ups, but the former is somewhat ugly and inflexible and the latter, while flexible is potentially expensive.
In some older houses I recall seeing an enlarged baseboard that included outlets. What’s your sense of a shop-made wire chase with integral outlets? — something that might be fixed to the base of the wall like a baseboard. The larger scale wire mold set-ups I’ve seen are pretty much the same as this, except that they are made of metal or pvc.
I’d provide ample space inside and for simplicity might even run romex in it, as opposed to individual conductors. The main thing is that I could tailor it to fit my application, and also adapt it later if need dictates.
Anything in the code that would flag this approach? It will be inspected.
Thanks in advance.
Andrew…
  1. renosteinke | Nov 25, 2008 06:07pm | #1
    Your generally required to use "listed" or "approved" components. The testing standards generally preclude the use of wood, or other flammable materials, for these components. The plastic wiremold, etc., has to pass a 'flame test.'
    Another code issue that might arise is the requirement of adequate protection if the wires are not run deep enough. Add the metak, and you get to make sure it's all bonded, etc.
    1. kleinchen | Nov 26, 2008 03:40am | #5
      Thanks for all the feedback. The flamability issue makes sense.However, for Romex, looks like the consensus is that so long as I have min 1-1/2 of protection I might be ok. I was thinking I would be at least this deep, especially since I want to also include shallow boxes for receptacles. Now the question is do I want to risk the inspector not buying it....Thanks again.
    xxPaulCPxx | Nov 25, 2008 08:17pm | #2
    How much room do you have to go forward?  I ask this as you can think of this basicly as a short interior wall, except it only needs to be 1/2 as thick as a regular wall.  The wires need to have a minimum distance from the outside for fastener protection, unless you are running them in metal tube.
    Also a CRX fanatic!
    Tu stultus es
  3. DanH | Nov 25, 2008 11:24pm | #3
    You can have whatever decorative covering you desire, but you'd have to run either romex or some sort of listed conduit through it. And, if romex, you'd have to be prepared with a convincing argument that the covering effectively protects the wire from mechanical damage.
    The mark of the immature man is that he wants to die nobly for a cause, while the mark of a mature man is that he wants to live humbly for one. --Wilhelm Stekel
  4. sungod | Nov 26, 2008 01:13am | #4
    1/2" dry wall is all that protects most romex. So just attach two 2X parallel and nail 1/2" drywall over it.
    Oh, you want more fancy, drywall the side too, add corner bead, mud and paint.
