Happy Holidays all. Am seeking info on “forever” problem. I have a Delta Contractor saw that sometimes trips the breaker on a 20 amp dedicated circuit either when I am doing heavy ripping and sometimes even on start-up. Circuit is 20 amp with about 55′ of #12 from main panel to outlet plus 6′ of saw cord. Saw motor is Rockwell 1.5 HP, 115 volt, 15 amp, service factor 1.0, KVA code J. Seems to me I did some figuring some time ago and came up with a necessary circuit size of 25 amp to properly feed saw. Have considered renewing all with 115 v, 30 amp breaker and new conductor.
I want to retain the 115 volt for motor as saw is often at other sites (where I trip 20 amp breakers). I want new circuit to be completely NEC legal. Obviously I have more questions than answers. Thoughts and suggestions would be greatly appreciated.
Does drilling new screws into the roof rafters compromise the strength of the roof?
Happy Holidays all. Am seeking info on "forever" problem. I have a Delta Contractor saw that sometimes trips the breaker on a 20 amp dedicated circuit either when I am doing heavy ripping and sometimes even on start-up. Circuit is 20 amp with about 55' of #12 from main panel to outlet plus 6' of saw cord. Saw motor is Rockwell 1.5 HP, 115 volt, 15 amp, service factor 1.0, KVA code J. Seems to me I did some figuring some time ago and came up with a necessary circuit size of 25 amp to properly feed saw. Have considered renewing all with 115 v, 30 amp breaker and new conductor.
