Electrical prep for new Workshop
danaho70 | Posted in General Discussion on October 13, 2012 12:35pm
 Hello everybody, My name is Scott and thanks for allowing me to post my question,
 I am in the process of building a new woodshop..Its 16×24 and It’s 30′ from the back of my home.. {Directly in line with my current electrical panel box}
 I am going to dig a trench to bury the necessary wiring etc.. from the box to the new shop..The shop is built on piers..{much like a deck}
 I am going to hire an electrician to do ALL OF the necessary wiring..
I have a table saw and a planer that run on 220, everything else is 110
My question is –
What kind of conduit do I put in the trench? Made of what? How big? One piece or seperate pieces? How deep?
I would appreciate any and all advice that I could get..Thanks a million,
 Scott
  1. gfretwell | Oct 13, 2012 01:42pm | #1
    I would run 1.5" PVC conduit
    I would run 1.5" PVC conduit buried 18" down minimum. Frost may make that deeper, ask locally. It doesn't freeze here ;)
    That will give you the most flexibility. If you think you might want water and low voltage, this is the time to drop those in the trench (3/4" PVC for the low voltage)
    The pipe will end up being the cheapest thing in this project and the hardest to change if your needs change.
    1. danaho70 | Oct 14, 2012 08:04am | #4
      Thanks for all of the replys.I never thought about water..
       what does "low voltage do" I mean what can you use it for..
        scott
      1. DanH | Oct 14, 2012 08:16am | #5
        Low voltage would be phone, cable TV, internet, maybe a doorbell/intercom, etc.  Basically all of your non-power wiring.
        1. danaho70 | Oct 14, 2012 09:47am | #6
          thanks dan..
      2. gfretwell | Oct 14, 2012 11:06am | #7
        Water is pretty handy in a shop, if for nothing else, just washing your hands. If this is just going to be gray water (no toilet) you can usually get away with simply dumping it out on a splash block in the yard. More elegant would be a small dry well, (30 gallon perforated trash can full of rocks buried in the yard). You can get a small under sink water heater pretty cheap.
  2. calvin | Oct 13, 2012 06:24pm | #2
    Extra pipe
    I agree fully in pulling "whatever" you might think of (phone,speaker, intercom (I know, old school), 3-4 way switching for outdoor shoplights,  NOW.
    And an extra pipe don't hurt neither
    1. DanH | Oct 13, 2012 08:52pm | #3
      You can't pull low-voltage through the same conduit as regular wiring, so install two conduits.
      1. dude | Oct 16, 2012 02:34am | #8
        When you say you cant pull low voltage through the same conduit as main feed is that code or does it cause electrical problems .
        I ran 3 inch pvc to my shop & pulled 100 amp cable through it plus 6 conductor intercom plus 8 conductors for phone ,alarm & fire & so far have had no problems 20 yrs later
        I dident realize it might be wrong at the time .
        Water for the bathroom is in the same trench about 4 ft deep due to frost & has never frozen .
          xxPaulCPxx | Oct 16, 2012 10:56am | #9
          Just imagine a cracked conductor touching a 120V line to your doorbell.  In the rain.
  3. sapwood | Oct 16, 2012 12:30pm | #10
    Your electrical contractor will be pulling the wire, so he should be the one to install the conduit.
  4. gfretwell | Oct 16, 2012 12:46pm | #11
    There are 2 legal ways to pull both in one conduit.
    If all of the wire is part of  listed cables (power and low voltage cables)  the conduit becomes a duct. but you have to terminate them in separate boxes.,
    You can pull an innerduct through (another flexible conduit) and pull one of the voltages through that.
    It is a lot easier to just drop a separate conduit in the trench and not take any chances that an inspector will have a different opinion. Interferance in the low voltage might be an issue but only if tyou are not running coax or twisted pairs. These days I am not sure why anyone would run anything but twisted pair. Cat5/6
