electrical remodel boxes
aeetes | Posted in General Discussion on October 17, 2004 05:43am
When drywall was added the electrial boxes are now a 1/2 recessed. There is enough wire to pull them out but I can’t find longer boxes.
The boxes used now are something like bakelite, a brown hard plastic, with little “wings” that open when tighten. The screws aren’t long enough and I’ve tried “adding” longer screws with no luck.
Any ideas are welcome for the dyi-er.
  1. DanT | Oct 17, 2004 05:53pm | #1
    Most electrical supply stores have a plastic spacer that comes in 3/8" and 1/2" depths that extend the box.  There are also metal box spacers used in commercial work.  Use the spacers, faster, cheaper but also saves you the removal time.  DanT
    1. aeetes | Oct 18, 2004 02:38am | #3
      Thanks.
    IMERC | Oct 17, 2004 05:59pm | #2
    Plaster rings or box extnsion...
    the big boxes have them....
    WOW!!!   What a Ride!
    1. aeetes | Oct 18, 2004 02:42am | #4
      thanks. I'll look
