Is it possible to cut a clean edge on an enamel over metal counter top?? Why, you may ask, well the counter top (unit) is an efficiency/ all in one-stove- sink- refrig. Cute litl bugger, problem is, that the refrigerator is beyond repair. So my optons are, 1. replace entire unit. 2. extract refrig only, and slip in an undercounter refrig. 3. Cut counter top, install a scaled down refrig, that would be apprx. 30″ wide and 60” tall, yes, I’am aware of losing the little bit of counter top space that is there, and cutting backsplash probaly the trickyest part. So, what type blade would one suggest on using(if any), or technique as to the approach. Thank You All, Jim J
Efficiency, solar power, and a sensitive kitchen for an 1830s house in New York.
You could try an abrasive blade on a 4" angle grinder. Don't know if it would chip the enamel or not. Tape the good edge, make a scoring cut first, then cut away. You might want to look for an old cast iron or steel sink that has emamel on it for a test...
Hi 44
Definitely recommend you score any cut line, possibly with a fine bladed tool prior to using the actual cutting tool. I believe I've seen that approach used in other materials to avoid chipping along the cut lines.
Also - is the enamel color one for which there are any touch up kits available? Just in case!
Good luck.
BJ
The enamel will chip, a little or a lot, and the edge will rust. So figure on that touchup paint.
SamT
Here is how I'll do it.
Score the enamel with a stone on a Dremel tool, bevelled toward the intended cut line.
Cut the steel just a hair shy of the scored enamel with a cut-off wheel on a grinder.
Finish with a belt sander or a sanding disc, sand from enamel to steel.
If everything fails, as SamT said, touch up kit.
Tom
TO ALL, finally a decision, "we" are going with a 24" undercounter fridge unit. Wow, it is sometimes amazing to me the amount of Phone calls and time one can make, researching an item. I did find out I could get a 30" wide underconter fridge for,,,, $1,200.00 plus $300.00 for freight, 8 to 10 weeks lead time. So, I threw all my options on the table, let some other people look at them, with me, and I'am in the process of chewing out the old 30" fridge in pieces- literally. I DO appreciate this forum, all that I learn from it, and I hope I never have to use these tips on cutting enamel over metal. Thanks all, Jim J
44.. the enamel is probably porcelain.. it's going to chip.. your labor will be very excessiver and the results questionable..
i'd think twice about the option of a new countertop
Thank you Mike. Be Safe out there, Jim J
