End grain flooring from scraps
Mike_Mahan | Posted in General Discussion on January 7, 2020 08:21pm
There was an antique post resurected on this topic, but I don’t like to enter into ancient discussions.
Many years ago, before I knew much about building, I was working with an architect who wanted to use construction scraps for end grain flooring. This seemed like a wonderful idea to use waste material for flooring. The only trouble was that he had no idea how much scrap was produced in normal construction or he hadn’t done the math.
The end of a 2×4 is 5.25 sq. in.. In a sq. ft. there would be about 27 pieces. For 15oo sq. ft. of flooring one would need 41,145 pieces. At 1 in. long that would amount to almost 3500 feet of scraps. End grain 6×6 would require 500 feet of lumber.
  1. calvin | Jan 07, 2020 08:28pm | #1
    Mike,
    I think it was in Nashville that I saw an old converted postal depot/post office where the sorting area had a floor of 4x4 ends. It was explained to me that the bedding below was cork. Evidently this eased the wear and tear of the workers.
      Mike_Mahan | Jan 07, 2020 09:00pm | #2
      They used wine corks.
  2. bobbomax | Jan 08, 2020 05:08pm | #3
    End-grain bedded in sand was once a common factory floor. It didn't require lot of concrete- wood was probably cheaper and more readily available- and it was easy to repair. Split the damaged pieces, pull them out and drive new ones in.
      Mike_Mahan | Jan 09, 2020 11:30am | #5
      End grain wood blocks were sometimes used for paving streets.
  3. bobbomax | Jan 08, 2020 05:10pm | #4
    Mike, in the era you're describing, the end of a 2x4 was 8 sq in.
