Ending a slanted top-cap: square cut or plumb cut?
geoffhazel | Posted in Construction Techniques on September 26, 2012 12:41pm
I have a half-wall on the side of a stairway, that comes down and ends at the foot of the stair.  I’m putting a flat cap board on the top.  I’m wondering about cutting the bottom edge. Choices are either a square cut, as it comes from the yard, or a plumb cut.  I looked at the board as I held it in the air at an angle, and a square cut didn’t look too bad, but I could go either way.
Recommendations?
  1. calvin | Sep 26, 2012 01:17pm | #1
    Usually, I'd ask the homowner how they want it.
    Personally, I suggest the plumb cut.  To me, all the parallel lines look the best.
  2. DanH | Sep 26, 2012 07:49pm | #2
    Yeah, we have that on our main entry stairway, and it's a plumb cut.  Looking at it I can't see how a square cut would look right.
  3. davidmeiland | Sep 26, 2012 11:14pm | #3
    Either
    To me it depends a bit on whether there are miters in the other trim, or if it's square cut. If you do the plumb cut, you probably need to do something to soften the sharp edge at the bottom.
    1. DanH | Sep 27, 2012 07:43am | #4
      At the bottom corner you just round it over (with sandpaper) to maybe a 1/64th radius -- just enough to smooth the cut edge.  No more radius than on the factory corners, probably less.
    hammer1 | Sep 27, 2012 08:42pm | #5
    Square cut for me, corners rounded or nipped at a 45, top edge profiled with a router, small molding tucked under. Nothing sharp like you may have with a plumb cut, somebody will get dinging up.
    1. DanH | Sep 27, 2012 09:13pm | #6
      It's not "sharp" -- never
      It's not "sharp" -- never once in 36 years here gotten "dinged" by it.
        hammer1 | Sep 27, 2012 10:14pm | #7
        Maybe you don't move all that fast, Dan, LOL! Actually, just a cap board looks a bit chintzy either way. What about going with a post to die against? Keep it simple or jazz it up.
        http://4.bp.blogspot.com/-E0oL_BlyVbk/TxPSsRKmHII/AAAAAAAAB6I/jvpiPMVAZvg/s1600/001.JPG
        1. DanH | Sep 27, 2012 10:28pm | #8
          The post works if you're going after a colonial style, I suppose.  Not so much if you want a simpler look.
  5. calvin | Sep 28, 2012 07:07am | #9
    yes
    With that detail underneath, that looks better.
Versatile Vise
