energy efficent crawl space vents
ron5359 | Posted in Energy, Heating & Insulation on August 10, 2008 12:21pm
I am currently building an addition on a house in MT.  The foundation is ICFs with TJI joist and rim joist.  The rim joists between the I-joists are insulated with two layers of loose fitting Dow board foam with the gaps filled with expanding foam.  I am looking for crawl space vents that can be opened in the summer and closed with a good amount of efficiency during the winter.  I am not considering a sealed and conditioned space on this addition as I have on new houses as the existing house would be impossible to seal. Thanks for any links or leads on this product.  Ron
  1. Clewless1 | Aug 10, 2008 06:23pm | #1
    I recall using a plastic vent a while back w/ a flap to close for the winter. It was a rectangular box about 8" deep and a plastic grid/screen and then a hinged flap to allow you to open/close it. I think it is still commonly available ... maybe even Lowe's/HD ... or your local lumber yard. You set them prior to concrete pour. Someone will probably jump in here w/ a link or manufacturer.
    1. ron5359 | Aug 11, 2008 07:46am | #2
      Hey thanks, I'm familiar with that style, I was just hoping that some manufacturer had come up with something a little more sofisticated.  I appreciate your response. Thanks, Ron
  2. JohnT8 | Aug 11, 2008 08:49am | #3
    Some glass block manufacturers have various accesories such as little windows (two blocks wide) or dryer vents with a block next to it.
    I have one of the 2-block wide windows.  It is basically the standard size of a crawl space vent hole, however in my case, they slathered some concrete on the bottom of the vent holes, so I will have to grind/chisel that away prior to being able to install the windows.
    But anyway, if I think of it, I will take a picture of one of them.  Little openable window with a screen.
    "A little 'enthusiasm' and all problems seems small!"
    1. ron5359 | Aug 12, 2008 04:53am | #4
      That sounds like kind of what I was hoping to find.  Thanks a bunch for the tip.  Will take a look at the glass block manufacturers.  Thanks, Ron
Drafting the 2027 IRC
  • The New Old Colonial
