I have a client who wants to give her general contractor a list of energy-efficiency contruction details he should pay attention to while building the house. I’ve started such a list, but am wondering if there is a book, magazine article, or web site that’s already done the job. Thanks.
Prescriptive codes don't address the connection at less common angles, so base the connection off more typical ones using bolts, structural screws, blocking, and steel tension ties.
Go to: http://sarup.uwm.edu/BridgNet/BN_GATE/sour_www.html
or http://www.eeba.org/ee-building-list-archive/ and http://www.nrg-builder.com/nrgeffic.htm
I personally prefer Structural Insulated Panels for the envelope as they are cost effective and if done correctly make a very efficient home.
Good Luck!
I found Northern Comfort - Advanced Cold Climate Home Building Techniques, published by The Alaska Craftsman Home Program, Inc. (900 W. Fireweed Lane, Suite 201, Anchorage, Alaska 99503-2509, 907-258-2247) quite good. Lots of info I hadn't seen before and presented well. Sample calculations and discussions of when extreme measures are and aren't justified. $40.00 from the "The Bookstore" in Homer, Alaska where I found it.
One approach my framing/sheathing contractor used, that I liked, was to use 2-3 inches of spray foam against the sheathing and fill the rest of the bay with a dense grade of fiberglass batting. You fill most of the volume with the cheap stuff but get a few inches of the high R-value/inch stuff as well as effect a secondary air-infiltration barrier in case there's a defect in the outer barrier (rip, nail hole, untaped seam, etc).
Chalking under the bottom plates is the quickest thing that will have a significant effect.
Where's the house to be?
-David
Mike. Read c hapter 11 of my book, _Complete_Building_Construction_ 4th Edition, published by Nacmillan. The other books or web sites recommended are quite good.Gene L.
I have a client who wants to give her general contractor a list of energy-efficiency contruction details he should pay attention to while building the house. I've started such a list, but am wondering if there is a book, magazine article, or web site that's already done the job. Thanks.
