FIRST BREAKTIME FORUMER HERE.IN NEED OF SOME INFO. I AM DOING A HOUSE
IN CALIFORNIA THAT IS BEING HEATED BY RADIANT SUBFLOOR TUBING,HYDRONICS,THE CLIENT IS LOOKING FOR ULTRA CLEAN AIR INSIDE,AND WANTS HEPA FILTRATION,WITH LITTLE TO NO VISIBLE REGISTERS.ANY LEADS FOR SPECIALTY SUPPLY HOUSES ,OR FIRMS THAT DISTRIBUTE “systems”?.
ALSO IF ANY BODY WITH EXPERIENCE HAS ANY DO’S OR DONT’S ,IT WOULD BE APPRECIATED.IV’E LOOKED AT THE FANTECH WEBSITE,SEEMED A LITTLE COMMERCIAL FOR A CUSTOM HOME.THANX,JOHN TAIT
Framing the floor inside a crawlspace foundation keeps a gable-end addition close to grade.
Welcome to breaktime, John.
All caps is considered yelling most of the time.
Need more information. Hydronic floor heat. What type of floor, wood, concrete,....?
Single story home , crawlspace, basement....?
Guys here are pretty good if they have enough information
Dave
John,
I'm not sure if this is new construction or an existing house.
If new and you're looking for a whole-house HVAC system, look into the hi-velocity systems out there. Companies like Unico and SpacePak.
They move air fast (hi-velocity) through small outlets, typically the outlet is a 4" disc with a 2" opening. The outlets can be painted, or they come in wood grain that can be stained. Outlets can go in ceilings, walls, or floors. Though the air exits the outlet at a high speed, it quickly blends with surrounding air, so no breezes, etc. The outlets can easily be blended into a room's decorating scheme.
They also have specialty outlets that fit in soffits or toe kicks. Those can be a bit noisier in terms of noise from air turbulence, but they are good at being inconspicuous.
If it's a remodel, you can use these systems as well. Just depends on how significant the remodel is.
Welcome to the forum.
Thanks for the replies ,I probably should have been a little more clear.it is a custom home,5000 sq ft ,three stories with afull basement,(4 stry).the entire house is sheeted with 1 1/8 ply then rad.
tubing with gyp crete,thermafloor,poured 1 1/2 " thick,then baked oak
flooring or imported saltillo style tile from france. what we are trying to do is,process the air in the house with a hepa filter ,or acombo of filter and uv to kill mold etc.we need to recirculate and clean and exhaust .also provide passive air intake /provide positive pressure with that air being processed before introduction to living.would like to know if there is a system out therethat islike a package or what manufacturers areproducing the highest quality product. thanks,johntait
