Entry Door Exterior Finish
myyou | Posted in General Discussion on November 20, 2009 07:18am
Is it ok to put spar varnish on the outside of a fir entry door and a coat of shellac or urethane on the interior side? I read an article in FH recently on door finishing but shellac was the only thing that was recommended. I think I need spar varnish on the weather side of the door but not sure if two different types of finish coats will be okay for opposite sides of the door.
Thanks,
Brian
  1. plumbbill | Nov 20, 2009 07:28am | #1
    Ever see a painted door on one side & stained on the other?
    Yes you can use two different finishes.
Drafting the 2027 IRC
  • The New Old Colonial
